Clutch Cable connection to cluster |
bd1308 |
May 24 2006, 05:56 PM
OK, so not only did a E-brake cable and a clutch cable become useless and riuned by the incident, but I found that my speedometer cable is leaking black oil-like substance all over the exterior of the cable, or was...
Anyway, I cant see where the clutch cable attaches to the clutster, nor can I make the pedal go to the floor, because it is currently connected and it is rather dark outside... show me what i can't see.... b |
So.Cal.914 |
May 24 2006, 06:04 PM
Disconnect clutch cable at the rear. (IMG:style_emoticons/default/blink.gif)
rhodyguy |
May 25 2006, 08:46 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,071 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
it's all pretty detailed in the chapter regarding the clutch, in your haynes manual.
k |
SLITS |
May 25 2006, 08:51 AM
It's daylight.....go look at it now or buy a flashlight if you are nocturnal.
TROJANMAN |
May 25 2006, 09:14 AM
Looks nice in pictures......... Group: Members Posts: 5,258 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
the black oil like substance is probably black oil :brilliant:
What exactly are you looking for? you didn;t post much of a question? I am sure there are alot of things you can;t see. Take "R" rated movies for one. (IMG:style_emoticons/default/laugh.gif) seriously, are you trying to hook up your clutch cable, or what? (IMG:style_emoticons/default/idea.gif) what incident? did i miss another post? loosen the cable inthe rear (as suggested) if you are trying to hook it up at the assembly. it will give you more room to work with. i am guessing you have already removed your carpet and pedal board? |
dwillouby |
May 25 2006, 11:15 AM
Member Group: Members Posts: 392 Joined: 27-December 02 From: Mt Washington, KY Member No.: 29 Region Association: None |
Britt,
I corrently have my pedal cluster out of the car. You could stop by and see how everything hooks up. We still up for the rust repair? David |
Aaron Cox |
May 25 2006, 11:18 AM
the black oil like substance is probably black oil :brilliant: .... I am sure there are alot of things you can;t see. Take "R" rated movies for one. (IMG:style_emoticons/default/laugh.gif) THAT my friend, was hilarious! (IMG:style_emoticons/default/chairfall.gif) britt.... did you see how the old one came off??? the new one goes on the same way. |
bd1308 |
May 25 2006, 11:24 AM
Yes we're still up for the rust repair....I just hope I have enough detail to explain the extent of the rust...but then again at worst we'll get the firewall fixed and the floorpan fixed. I think I'll be amazed at the end of this I think.
:bitingnails: b |
dwillouby |
May 25 2006, 11:47 AM
What day are we doing this? I think you said the 1st. Thats thursday. The weekend is much better for me.
Let me know your address and what time to show up. David |
bd1308 |
May 25 2006, 03:55 PM
fixed.
this thread is closed. |
rhodyguy |
May 25 2006, 05:37 PM
ok.
grasshopper |
May 25 2006, 05:42 PM
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
hey dwillouby, It will take more than one day, so I wil be working late, as late as I can, and not make anyone mad with the grinding and welding and cutting..do you happen to have an air compressor you could bring?? sorry for the hijack britt
dwillouby |
May 25 2006, 06:11 PM
No my compressor is not portable. I can come after work Thursday and Friday,Help all day Sat.
Let me know. David |
grasshopper |
May 25 2006, 06:28 PM
new thread, check in there
Lo-Fi Version | Time is now: 3rd May 2024 - 09:33 AM |
