bd1308
May 24 2006, 05:56 PM
OK, so not only did a E-brake cable and a clutch cable become useless and riuned by the incident, but I found that my speedometer cable is leaking black oil-like substance all over the exterior of the cable, or was...
Anyway, I cant see where the clutch cable attaches to the clutster, nor can I make the pedal go to the floor, because it is currently connected and it is rather dark outside...
show me what i can't see....
b
So.Cal.914
May 24 2006, 06:04 PM
Disconnect clutch cable at the rear.
rhodyguy
May 25 2006, 08:46 AM
it's all pretty detailed in the chapter regarding the clutch, in your haynes manual.
k
SLITS
May 25 2006, 08:51 AM
It's daylight.....go look at it now or buy a flashlight if you are nocturnal.
TROJANMAN
May 25 2006, 09:14 AM
the black oil like substance is probably black oil :brilliant:
What exactly are you looking for? you didn;t post much of a question?
I am sure there are alot of things you can;t see.
Take "R" rated movies for one.
seriously, are you trying to hook up your clutch cable, or what?
what incident? did i miss another post?
loosen the cable inthe rear (as suggested) if you are trying to hook it up at the assembly. it will give you more room to work with. i am guessing you have already removed your carpet and pedal board?
dwillouby
May 25 2006, 11:15 AM
Britt,
I corrently have my pedal cluster out of the car. You could stop by and see how everything hooks up.
We still up for the rust repair?
David
Aaron Cox
May 25 2006, 11:18 AM
QUOTE(TROJANMAN @ May 25 2006, 08:14 AM)
THAT my friend, was hilarious!
britt.... did you see how the old one came off??? the new one goes on the same way.
bd1308
May 25 2006, 11:24 AM
Yes we're still up for the rust repair....I just hope I have enough detail to explain the extent of the rust...but then again at worst we'll get the firewall fixed and the floorpan fixed. I think I'll be amazed at the end of this I think.
:bitingnails:
b
dwillouby
May 25 2006, 11:47 AM
What day are we doing this? I think you said the 1st. Thats thursday. The weekend is much better for me.
Let me know your address and what time to show up.
David
bd1308
May 25 2006, 03:55 PM
fixed.
this thread is closed.
rhodyguy
May 25 2006, 05:37 PM
ok.
grasshopper
May 25 2006, 05:42 PM
hey dwillouby, It will take more than one day, so I wil be working late, as late as I can, and not make anyone mad with the grinding and welding and cutting..do you happen to have an air compressor you could bring?? sorry for the hijack britt
dwillouby
May 25 2006, 06:11 PM
No my compressor is not portable. I can come after work Thursday and Friday,Help all day Sat.
Let me know.
David
grasshopper
May 25 2006, 06:28 PM
new thread, check in there
