Is this what I need?, Ignition |
cbenitah |
May 24 2006, 06:29 PM
Protected by the Swedish Maffia Group: Members Posts: 848 Joined: 16-August 05 From: San Diego, CA Member No.: 4,597 |
Since I lost all my Keys a few weeks back I have decided to go and get a new key done. 2 guys tried to make a new key, they both failed.. (IMG:style_emoticons/default/chair.gif) So if I need a new ignition.. is this what I need? Seams too cheap if you'd ask me..
Or is there a way YOU know about that I don't? Called Porsche as well and they dont have any records of older cars they said. Ignition |
type47 |
May 24 2006, 06:32 PM
to me, when i looked at the switch that popped up from your link, i do not think that's what you need as i think that one is for a -6. of course, unless you have a -6...
Joe Ricard |
May 24 2006, 06:35 PM
I could only get the electrical portion to come up.
You need the tumbler setion or just pull the unit out and re key everything. Plenty of guys here that can do that. Even me but I don't have time. |
cbenitah |
May 24 2006, 06:39 PM
Anything I can tell the lock smith? I get it for free if they do it through my insurance.. They did try to make a new key for it but failed.. Kinda bumbed about it right now. Any advice would be great
Cap'n Krusty |
May 24 2006, 06:46 PM
What year is your 914? Makes a difference. The Cap'n
cbenitah |
May 24 2006, 06:49 PM
1974, what is the difference?
Cap'n Krusty |
May 24 2006, 06:57 PM
Early cars use a different tumbler. You need the tumbler, not the switch. Porsche keyed tumblers are probably NLA, but I can get VW ones with a round rubber head, and they're pretty reasonable. Did one key work for all the locks in the car? If so, can you take out the front or rear trunk lock? If not, it doesn't matter. Removing the ignition switch assembly with the steering lock can be a challenge if you don't have the key, so there's gonna be a bit of learning and effort involved, including the use of a drill.
Mark Britell might have a good tumbler with key to fit your car, BTW. Used, of course. The Cap'n |
willrc |
May 24 2006, 07:56 PM
Newbie Group: Members Posts: 30 Joined: 5-February 05 From: napoleon, ohio Member No.: 3,561 |
Since I lost all my Keys a few weeks back I have decided to go and get a new key done. 2 guys tried to make a new key, they both failed.. (IMG:style_emoticons/default/chair.gif) So if I need a new ignition.. is this what I need? Seams too cheap if you'd ask me.. Or is there a way YOU know about that I don't? Called Porsche as well and they dont have any records of older cars they said. Ignition lost my keys a few years back. Took off the trunk lock by putting a plastic wedge in between the trunk and removed the two bolts holding the trunk locked. took the trunk lock to the locksmith and they made me a new set of keys. porsche used all tumblers in the locks for all the car. first key cost me $45. the second only $5. Car was also a 1974. hope this helps |
rcrgrl |
May 24 2006, 08:57 PM
Member Group: Members Posts: 202 Joined: 19-April 06 From: San Diego, CA Member No.: 5,893 |
i know a locksmith in town that doesn't do cars, but he might know a guy - i'll ask in the am and let you know i fyou haven't come up w/anything.....plus i can see if hte guy that did mine is open sat and i wouldn't mind taking a lock up for you if he is - & you can wait...
cbenitah |
May 24 2006, 11:09 PM
i have welded my trunk lock shut and have the assembly here next to me. is that all they need you think??? I have never tried to open the trunk with my key. i just know that I couldnt open passanger door with my key i opened the driver door with. and driver door key did not work in the ignition... should i try with the trunk lock??
echocanyons |
May 24 2006, 11:13 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
QUOTE they dont have records That is total BS less than one year ago I had two porsche made keys. They didnt copy them they had them made based on the VIN Go to the parts dept. and ask to have keys made. They will need your registration and proof of ownership. It's not cheap but if you want the correct key it will work |
echocanyons |
May 24 2006, 11:15 PM
Also turn around was a wait like two weeks they had them made from Porsche NA
cbenitah |
May 24 2006, 11:17 PM
then they are good at (IMG:style_emoticons/default/bs.gif) ... since I called today and walked in. when they ran my VIN nothing came up (they said) tried to see if they had an ignition i could buy instead (IMG:style_emoticons/default/sad.gif) but not even that.. Maybe they didnt want my business i dont know.. I'll call tomorrow and try for my trunk, im hoping that will do the trick
Dr Evil |
May 24 2006, 11:31 PM
You can't be sure that the ig is origianl anyway. If your passenger side would not open it could be because it is broken on the inside. Have a locksmith look at your trunk and your doors and see if they match. At least you will know if they are the same and can go from there. Many of us can do them for you and see.
dlo914 |
May 25 2006, 12:55 AM
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
you could send your ignition tumbler to MarkB on the forum and he could rekey your tumbler to any key you sned him.
Lo-Fi Version | Time is now: 3rd May 2024 - 06:44 PM |
