Compu fire difference for 009 or vac advance |
Thack |
May 24 2006, 07:47 PM
Member Group: Members Posts: 283 Joined: 1-June 05 From: Houston, Tx Member No.: 4,182 |
Why would the Compu-fire magnetic pickup be different from a Bosch 009 distrib and a vac advance one?
lapuwali |
May 24 2006, 07:50 PM
The Compufire is meant to mount to the points plate just like a set of points. The points plate on the 009 is different from the vacuum advance distributor you're thinking of (there are actually quite a few that will fit).
john rogers |
May 24 2006, 08:38 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
The difference between the two models is the height of the rotating plate with the 4 magnets. The top of one fits higher than the other, sorry I forget which is taller but if use the wrong one either there will be no spark or the center button in the cap will be crushed.
Thack |
May 24 2006, 10:41 PM
I once used a cheap Accu-fire. After it got warm it started to rub and would not fire. But the accu-fire has only one part for the bosch distributor. Thanks for the tip. I can work with that.
Lo-Fi Version | Time is now: 17th May 2024 - 07:05 PM |
