Best Product for Repair..., ...of a cracked tail light lens |
D1A3 |
May 24 2006, 09:44 PM
Gruppe Neun Vierzehn Südosten Group: Members Posts: 362 Joined: 3-June 04 From: Atlanta, GA Member No.: 2,152 Region Association: South East States |
I heard there was a very good "product" to use to repair your tailight lens when it cracks. Mine has cracked along the seam between the clear and the red sections. What do you guys think is the best to fix this?
I went to my FLAPS and they suggested superglue. Before I try to "glue" it back together, I wanted to get some ideas from anyone who has done this before. What about epoxy? Any other product that should be considered? |
GWN7 |
May 24 2006, 11:08 PM
super glue drys clear. Put it on from the backside of the lens and then turn it over to let the excess drip down on to a piece of paper towel.
smdubovsky |
May 25 2006, 07:19 AM
Member Group: Members Posts: 331 Joined: 27-September 04 From: Silver Spring, MD Member No.: 2,837 Region Association: MidAtlantic Region |
But superglue will out gas and leave a white power on the lens. You can rub it off but it will come back (well, it may eventually stop). If the lenses can be melted w/ a nitro-tolulene based plastic glue (same stuff you use to put model cars together), it would be a far better choice. Its designed to actually melt the plastic and fuse them together (if the plastic is a compatible one.) Nylon for example wont chemically melt and is impossible to glue together...
SMD |
solex |
May 25 2006, 07:26 AM
Senior Member Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
SMD, are the sun visor clips made of nylon? I need to repair one and am looking for a glue, super glue does not work.
Hammy |
May 25 2006, 07:36 AM
I had a tail light lens somehow end up on the floor and of course somehow ended up getting stepped on .
Super glued it.. Worked okay, got that white residue on it. Doesn't look horrible though. |
Eric_Shea |
May 25 2006, 08:45 AM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
2-part Epoxy
D1A3 |
May 25 2006, 08:11 PM
Thanks Eric. I was thinking the two part epoxy as well. I seem to remember different "formulas" at my FLAPS. Is there any particualr brand or "mix" you recomend?
Eric_Shea |
May 25 2006, 10:17 PM
There's 5 minute stuff but I like the good old variety that should probably cure 24 hours. They seem to work better. I think the hardening agents in the quicky stuff make them more brittle.
Glue them up and stick them on thop the fridge with the dust bunnies. |
Lo-Fi Version | Time is now: 3rd May 2024 - 03:29 PM |
