WTH: I bought the wrong rotors |
swood |
May 25 2006, 09:52 AM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Tough crowd, I did confess my idiocy earlier...
Don't start making suggestions Eric that will cause me to never finish. Although it might be timely to go to 5 lug, that might put me over the edge. You're an enabler. Stop it. (IMG:style_emoticons/default/smile.gif) |
Aaron Cox |
May 25 2006, 10:40 AM
STEVE STEVE STEVE.....
and since you are doing 5 lug....you should flare it, so you will have enough rubber to hook up with that big six you are trying to install (IMG:style_emoticons/default/smile.gif) |
SLITS |
May 25 2006, 10:46 AM
STEVE STEVE STEVE..... ....you should flare it, so you will have enough spread to hook up with that big six you are trying to install (IMG:style_emoticons/default/smile.gif) Kinda like you do with your butt cheeks when Matt or Zois is behind you? |
Aaron Cox |
May 25 2006, 10:48 AM
STEVE STEVE STEVE..... ....you should flare it, so you will have enough spread to hook up with that big six you are trying to install (IMG:style_emoticons/default/smile.gif) Kinda like you do with your butt cheeks when Matt or Zois is behind you? i picked up a thing or two from you..... (IMG:style_emoticons/default/blink.gif) asshole (IMG:style_emoticons/default/chairfall.gif) |
swood |
May 25 2006, 10:52 AM
STEVE STEVE STEVE..... ....you should flare it, so you will have enough spread to hook up with that big six you are trying to install (IMG:style_emoticons/default/smile.gif) Kinda like you do with your butt cheeks when Matt or Zois is behind you? Ahhhh ha ha ha. Ha. (IMG:style_emoticons/default/chairfall.gif) |
SLITS |
May 25 2006, 10:56 AM
get off the 'puter and go to class....ya might learn the difference between 5 X 130 and 4 X 130.....it's 18 degrees
And yes I am an ASSHOLE and you can (IMG:style_emoticons/default/KMA.gif) it. (IMG:style_emoticons/default/av-943.gif) |
Lo-Fi Version | Time is now: 3rd May 2024 - 08:03 PM |
