Anton |
Royal Orange ![]() ![]() Group: Members Posts: 161 Joined: 25-March 03 From: The Netherlands Member No.: 473 ![]() |
QUOTE(thesey914 @ Sep 28 2003, 01:46 AM) Don't think the L jet is too tolerant of lots of overlap. An aggressive cam might be too much, but a larger displacement of let's say +15% should easily tolerable for an L-jet system. However, you have to adjust the airflow sensor for the larger volume! Usually, getting more fuel into an engine is not the problem, but getting more air is. A larger displacement, aggressive cam, and some other modifications gets you more air; the fuel will "follow"... I have a 1.8 L-jet in good condition with ultrasonically cleaned injectors, adjusted airflow sensor, new fuel lines (!!!), high flow cotton air filter, 2.0 exhaust system, and it is a serious 914. It has a standard cam, but FLAT (not dome shaped) Mahle pistons with an increased compression ratio of about 8.5:1... IMPO the only thing better is a TUNED, ie. modified 2.0 engine (larger displacement, aggressive cam with Webers, etc.). Nevertheless, for AX you probably need something more than a 1.8. |
netwolf232 |
Newbie ![]() Group: Members Posts: 21 Joined: 5-September 03 From: San Diego, CA Member No.: 1,113 ![]() |
What should I expect to pay for a '73-2.0 3rd owner. Had it for 12+ years.
No accidents. No rust, $6K in engine/transmission receipts? the body has a dent on the left side of the car. Solid condition. I am waiting on pictures. Thanks -Andrew |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Depending on alot of things like paint condition, rust issues, battery tray condition, trunks condition, interior condition.
Say, $3000-7500 as it alll depends....... Pics will help alot. Geoff |
netwolf232 |
Say the paint is rough, the interior is rough (but comes with all new material to replace it) the engine is in very good shape as well as the tranny. What is everyones opinon about buying a car without seeing it in person? Thanks
-Andrew |
Qarl |
Shriveled member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None ![]() ![]() |
I've always loved my 1.8s (all I ever had). I had stockers with a K&N filter, bursch exhaust, SSIs, and pertronix ignition, and they always seem to run really nice. otherwise the FI was untouched.
I always had rough running 1.8s to start. I just made sure the hoses were new, the injectors were cleaned, and the CHT was in spec. One 1.8 had a gunked up throttle position sensor and another had a leaking cold start valve. I cleaned the TPS and replaced th cold start valve and all was well. |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,257 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
my 1.8 got a 1.7 d-jet transplant, i then took out all the un-needed, like the decel-valve etc., and it runs really strong.
i even disconnected the AAR, still runs fine, even when cold. just hooked up the oil-temp sending unit and i haven't gotten more than 130 in oil-temps ... i'm happy (IMG:style_emoticons/default/smile.gif) Andy |
Bleyseng |
Andy, I hope that is Fahrenheit not Celsius!
Geoff |
QUOTE(Bleyseng @ Sep 29 2003, 09:52 PM) Andy, I hope that is Fahrenheit not Celsius! yes, got one of those "wrong" gauges (IMG:style_emoticons/default/smile.gif) , range is from 120F to 300F and so far, i haven't been able to get over 130F ... Andy |
jarbuthnot |
Senior Woman Driver ![]() ![]() Group: Members Posts: 201 Joined: 22-August 03 From: Pembroke, ME Member No.: 1,065 ![]() |
QUOTE(netwolf232 @ Sep 29 2003, 09:10 PM) What is everyones opinon about buying a car without seeing it in person? I live in Maine and recently bought a car in Oregon. However, I did have a pre-purchase inspection on the car, which it passed. Based on the PPI, a lot of pictures and the opinions of many from this board, I basically bought it sight unseen and then flew out and drove it home. But I wouldn't have done it without the PPI. |
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
Hey Joan! How are you!?
Nice to see you back! Miles |
Bleyseng |
Joan, that was one of the few cars that you could buy sight unseen.
How do you like that color now??? (IMG:style_emoticons/default/laugh.gif) Geoff |
netwolf232 |
Was there any differences as far as the bodies, suspension, etc. between the different engines. was a 1.8 suspension different than a 2.0L? Did sway bars come stock on any models any years?
-Andrew |
jarbuthnot |
QUOTE(Bleyseng @ Oct 1 2003, 01:18 AM) How do you like that color now??? (IMG:style_emoticons/default/laugh.gif) It's growing on me and it goes well with my hair (IMG:style_emoticons/default/wink.gif) |
redshift |
QUOTE(netwolf232 @ Oct 1 2003, 01:28 AM) Was there any differences as far as the bodies, suspension, etc. between the different engines. was a 1.8 suspension different than a 2.0L? Did sway bars come stock on any models any years? -Andrew LE (74) cars have the good stuff package.. sway bars. 2.0s have alloys The limos came with rear side curtains in Pasha, and a decanter designed by Harry Winston. M |
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
In 73 the 2.0 cars came fully optioned. (including bars? I dunno on that) In 74 everything was a la carte.
redshift |
Actually, a high percentage of 73 2.0s get the sport stuff, but NOT all.
There are a ton of cars out there without sways, and without consoles, most all have fogs. Be on your toes. M |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,339 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
We have a 73 2.0 with swaybars, but no fogs. Also have 73 1.7 with everything except sways.
Anton |
QUOTE(netwolf232 @ Sep 30 2003, 09:28 PM) Was there any differences as far as the bodies, suspension, etc. between the different engines. was a 1.8 suspension different than a 2.0L? Did sway bars come stock on any models any years? -Andrew The main thing is that 1.8s have a side shift tranny just as 2.0s.! The so called "appearance group" package was very popular and included chrome bumpers, vinyl targa bars, console, dual horns, and fog lights. You could order it irrespective of 1.8 or 2.0 engine. Most 914s have this package and that explains "the luxury"! Sway bars, light metal alloys, and coloured glass were separate options, also irrespective of 1.8 or 2.0 engine. Right sided mirrors were never an option and had to be installed by the dealer if desired. |
redshift |
Actually, there is a part number for the right side mirror, complete with -objects in mirror probably not a porsche- thingy.
M |
Lo-Fi Version | Time is now: 12th July 2025 - 12:08 PM |
