EGR Routing Question and Charcoal Cannister, '76 914 California vs 49-State: Do I have it correct? |
Brian Mifsud |
May 25 2006, 01:41 PM
Mechanical Engineer Group: Members Posts: 981 Joined: 3-March 03 From: Penngrove, CA Member No.: 384 Region Association: None |
Attached is a New-Jersey original Concourse '76 (photo stolen from Concourse Forum). There is a "block off plate" on the end of the air cleaner. Was this standard on "49-State" cars for '75 and '76?
The charcoal cannister seen is something I just realized I'm missing and probably will fail visual on smog if I don't have.. but I don't remember it on my California original '76 2.0 when I had the original engine. Is this the correct placement, or did it sit somewhere else in the car? thanks Attached image(s) |
mikerose |
May 25 2006, 01:44 PM
Happy to be back Group: Members Posts: 657 Joined: 31-December 02 From: Pittsburg,ca Member No.: 60 Region Association: None |
Yep that's were mine was. 76 2.0 ca smog car.
Mike |
mikerose |
May 25 2006, 01:47 PM
and on my 75 1.8L smog car.
Brian Mifsud |
May 25 2006, 01:52 PM
Thanks for the quick confirmation Mike
Demick |
May 25 2006, 01:56 PM
During the 1974 model year, the charcoal canister was moved from the fuel tank area to the engine bay. On my '74 2.0, the charcoal canister is located at the rear passenger side of the engine bay, and is not normally visible unless you look for it.
Demick Attached image(s) |
VWnDRAG |
May 25 2006, 02:20 PM
Member Group: Members Posts: 69 Joined: 23-September 05 From: Hollywood, CA Member No.: 4,850 |
Porsche probably moved all charcol caniters to the battery tray just to make room for the EGR valves installed on the 1.8's in 1975.
The 74 loaction was better, I think, but then came the EGR valves on smog cars. Wouldnt fit there anymore. Had to move it. (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 3rd May 2024 - 05:52 PM |
