So one day it drops when you don't want it too and the next it dos |
GWN7 |
May 26 2006, 10:44 PM
everything is undone and all I have to do is undo the bolts that go thru the mount bar and it should drop. Well I had to take a 4' lenght of pipe and put that over a breaker bar to snap the bolt heads off and it's still hanging there. So I figure if I drop the jack a bit the weight should cause it to drop. Wrong again. Hitting it with a hammer was no help, so I got the favorite 914 tool out (IMG:style_emoticons/default/sawzall-smiley.gif) and it finally dropped. (IMG:style_emoticons/default/smile.gif)
VegasRacer |
May 26 2006, 11:34 PM
ELVIRA Group: Benefactors Posts: 8,509 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
I'm glad it didn't drop on your foot. (IMG:style_emoticons/default/ohmy.gif)
messix |
May 26 2006, 11:36 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
what you cut the whole effin thing out mount on the tub too?
GWN7 |
May 27 2006, 12:15 AM
Yep, the bolt is rusted inside the engine bar so bad it's like it's welded in there, so it cut it right off.....Broke 4 sawsall blades doing both sides
grasshopper |
May 27 2006, 10:49 AM
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
why didn't you just cut the bar and get the bolt when the engine was out??
Joe Bob |
May 27 2006, 10:53 AM
Too easy...Mongo LIKE noise....
GWN7 |
May 27 2006, 02:31 PM
why didn't you just cut the bar and get the bolt when the engine was out?? The object was to get the engine and the bar out. Those I need. I didn't care about the body as it is too badly rusted to ever see the road again. This car is worse than the orange 72 that broke in 1/2 while being taken to the farm. And Z was pretty close.....imagine me with a 5' lining bar prying up and down on the engine bar trying to get it to drop and all that was happening was the car was lifting off the jackstands. After a few minuites of that was when the (IMG:style_emoticons/default/sawzall-smiley.gif) came out. If I had a plazma cutter I would have made smoke. (IMG:style_emoticons/default/biggrin.gif) |
fitsbain |
May 27 2006, 08:23 PM
Ask me if my car has rust!!! Group: Members Posts: 619 Joined: 25-February 06 From: Pittsburgh PA Member No.: 5,634 |
NNOO!!!!
I need that part!!! LOL good work but I really do need a passanger mount. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:56 PM |
