Correct finish on alloy wheel lug bolts |
1970 Neun vierzehn |
May 27 2006, 12:46 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
What is the correct finish on the lug bolts for Pedrini, Mahle and Fuchs alloy wheels? Silver paint? Black paint? Plastic caps (IMG:style_emoticons/default/icon8.gif) And, of course, everytime you remove the wheels and then remount them, you scuff the finish on the bolts once again. How were they finished originally, and how's an easy way to maintain a nice finish on them today? My '70 was originally delivered with 4.5" steelies w/hub caps AND aluminum trim rings (IMG:style_emoticons/default/icon8.gif) . Since my Pedrinis were fitted 20 years ago, I have no idea how the bolts were finished when new.
smg914 |
May 27 2006, 02:35 PM
Sahara Beige Steve Group: Members Posts: 1,962 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 Region Association: None |
The original factory finish on the 914 alloy lug nuts.......Silver Annodized.
JeffBowlsby |
May 27 2006, 03:59 PM
914 Wiring Harnesses Group: Members Posts: 8,485 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The original factory finish on the 914 alloy lug nuts.......Silver Annodized. The wheels are alloy, the lugs are steel...you cannot anodize steel. The lug bolts are silver cadmium plated. (IMG:style_emoticons/default/biggrin.gif) |
Pat Garvey |
May 27 2006, 06:32 PM
The original factory finish on the 914 alloy lug nuts.......Silver Annodized. The wheels are alloy, the lugs are steel...you cannot anodize steel. The lug bolts are silver cadmium plated. (IMG:style_emoticons/default/biggrin.gif) Well, as someone who's never had "real Porsche" alloys, but does have "real Porsche alloy lugs", I'd have to agree - silver anoldizing. Anyone need these things - I don't & never will. I'm a steel guy! |
JeffBowlsby |
May 27 2006, 07:51 PM
I think we are talking about two different things here...Aluminum (alloy) wheels and aluminum (alloy) lug nuts.
Factory 914 alloy wheels like the 4-bolt Fuchs, Mahles and Pedrinnis require steel lug bolts, they have a domed top and are silver cad plated. The only other 914 wheel bolts are the smaller steel bolts for the steel wheels. Steel is not a material that anodizing works with, its only process for aluminum. 911s and sometimes 914s (racers mostly) retrofit wheel studs pressed into the hubs which use aluminum alloy lug nuts..those aluminum parts might be anodized or even powdercoated (black)..I dont know I never really looked at them... |
73Phoenix20 |
May 27 2006, 08:38 PM
Member Group: Members Posts: 334 Joined: 15-June 05 From: Michiana Member No.: 4,283 |
[/quote] The 911's, 944's, 928's, etc. used a black anodized aluminum lug NUT (not a bolt) from the factory. I have a bucket of them around the garage somewhere. They got torn up more easily than the Steel Lug Bolts for the 914. But a nice silver paint covers the scuffed up 914 steel lug bolt heads very nicely! I suppose silver cad plating would be great too! |
smg914 |
May 27 2006, 09:20 PM
The original factory finish on the 914 alloy lug nuts.......Silver Annodized. The wheels are alloy, the lugs are steel...you cannot anodize steel. The lug bolts are silver cadmium plated. (IMG:style_emoticons/default/biggrin.gif) Oops, your absolutely correct. I meant to say silver cad not annodized. I'm at the age now that I don't always say what I mean. Getting old sucks. |
May 28 2006, 10:42 AM
So we(mainly youz) have determined that these steel lug bolts are(should be) silver. How do I get this finish back on these discolored bolts? Steel wool? Metal polish? Chemical stripper? Buffing? Maybe one or two look (mostly)silver, but the rest have a blackish/silver mottled appearance to them.
Pat Garvey |
May 28 2006, 11:03 AM
So we(mainly youz) have determined that these steel lug bolts are(should be) silver. How do I get this finish back on these discolored bolts? Steel wool? Metal polish? Chemical stripper? Buffing? Maybe one or two look (mostly)silver, but the rest have a blackish/silver mottled appearance to them. I'm sure everyone has a technique. What I'd use is a fine wire brush in a Dremel to remove corrosion/rust, until you have clean steel. Then, I'd use the Dremel again, with a cloth buffing wheel & a light coating of Simichrome. They'll come out looking like a near-chrome finish. Problem is that you'll need to periodically redo them w/Simichrome, but it can be done with the bolts in the wheel & a soft cloth. Not sure what it would cost to have them re-silver cadded, but that would only last as long as the first time you put a lug wrench to them. Same thing if you clear coated them after polishing them. |
TJB/914 |
May 28 2006, 03:55 PM
Mid-Engn. Group: Members Posts: 4,326 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest |
Hi guys (Steve & Jeff)
I vote for the correct lug nut finish as Silver Cadmium Plate. Just want to show some aluminum air intakes I just got finished by a local shop. Learned Aluminum is the only metal you can anodize. Here's some Aluminum parts I had "flat black anodized". One of them didn't come out well and I have to sand it down to remove scratches & pits to get a perfect finish. Tom Attached thumbnail(s) |
Pat Garvey |
May 28 2006, 06:52 PM
Hi guys (Steve & Jeff) I vote for the correct lug nut finish as Silver Cadmium Plate. Just want to show some aluminum air intakes I just got finished by a local shop. Learned Aluminum is the only metal you can anodize. Here's some Aluminum parts I had "flat black anodized". One of them didn't come out well and I have to sand it down to remove scratches & pits to get a perfect finish. Tom They look like artwork! Shame to put them into an engine bay, only to get treated so badly (as engine bays do to parts). By the way, it looks like they were photo'd on something w/red paint? What's that? |
smg914 |
May 28 2006, 07:08 PM
Here's a picture of the lug nuts with the correct finish.
TJB/914 |
May 28 2006, 07:51 PM
Hi Pat Garvey,
You asked what's that red paint under those black anodized parts. I know it's OT but I spent all day polishing the wifes 1990 Mercury Cougar with the supercharged motor (same car as the T-Bird Super Cpe). Car is a creampuff with 60K orig miles & oil changed every 3K. No one has ever sat in the back seat & about (2) times (me) on the front passenger seat. Were getting her a new car next spring & it's for-sale. I wonder if I can get $6,000 for it next spring???? Little old (middle age) lady's future collector car. Tom Attached thumbnail(s) Attached image(s) |
914runnow |
May 29 2006, 12:52 PM
Member Group: Members Posts: 340 Joined: 19-April 04 From: Modesto California Member No.: 1,948 Region Association: None |
What is the correct finish on the lug bolts for Pedrini, Mahle and Fuchs alloy wheels? Silver paint? Black paint? Plastic caps (IMG:style_emoticons/default/icon8.gif) And, of course, everytime you remove the wheels and then remount them, you scuff the finish on the bolts once again. How were they finished originally, and how's an easy way to maintain a nice finish on them today? My '70 was originally delivered with 4.5" steelies w/hub caps AND aluminum trim rings (IMG:style_emoticons/default/icon8.gif) . Since my Pedrinis were fitted 20 years ago, I have no idea how the bolts were finished when new. Mecedes and Audi both use Dacromet on their wheel bolts..Google Dacromet.. IF you do not mind a 17mm head on the long wheel bolts for the alloy wheels,,, (and the head is flat) the Audi one will work better than that $45 junk ebay set that is chromed...Around 3.50 each I have a source... The Ebay ones>Threads are off pitch a bit and can possibly strip your rotors......#2= the 'radius' is way off on the dome..And can back out!!!!Beware of the ebay cheapies!! My 73 2.0's on my Fuchs were original to the car...Had the Dacromet type finish to them...Green Production paint stripe on them.. And the black caps as covers... I had my originals 'Clear' Zinc coated...(silver)...They came out horrible... Even a bit of a greenish tint to them.... Dacromet in my terms would be the best ..... on the bottom of my wheel bolts is stamped KX with the VW circle symbol.. I have a set of new ones from Porsche..That have close to a chrome finish on them..(not as wonderfully machined as the originals) and no markings... Does anybody else have a new set From Porsche out there??? Now on the early wheels.. I have pulled black and silver off of various years...Shorter and longer... Seemed the star (X) 74 thru 76 steelies were a bit longer than the older steelies.. ALL had VW stamped on them..... |
Jun 1 2006, 02:44 PM
smg914,
NICE wheelwell! (IMG:style_emoticons/default/clap56.gif) That is the finish I was hoping/looking for. I'll try the Garvey methodology first with the wheels still mounted on the car and see how they clean up. Thanks to all for the input. |
davep |
Jun 5 2006, 03:30 PM
914 Historian Group: Benefactors Posts: 5,137 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
AFAIK, the alloy-wheel bolts are first copper plated over the steel, then cad plated. I'll check with the plater when I drop in there. The plating should be tough enough to last several years worth of occasional wrenching.
914werke |
Dec 21 2009, 11:03 AM
"I got blisters on me fingers" Group: Members Posts: 10,030 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Ok enough on the Lugs what about the Painted wheels? Mahles. On non-LE cars these are painted silver on LE cars they are two-tone, either Red or Yellow centers and silver rim edge... but what about the backside and inside of the wheel~?
Was that trim color or the silver ? (IMG:style_emoticons/default/confused24.gif) Anyone with an surviving OE LE wheel? |
MDG |
Dec 21 2009, 11:39 AM
Wolf in wolf's clothing. Group: Members Posts: 8,652 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None |
Can't answer your question on the LE wheels, Rich, but I just learned something. My '73 that I drove thoughout the '80s had Mahle wheels - love them BTW - and I had no idea the silver finish was painted.
smg914 |
Dec 21 2009, 02:08 PM
Ok enough on the Lugs what about the Painted wheels? Mahles. On non-LE cars these are painted silver on LE cars they are two-tone, either Red or Yellow centers and silver rim edge... but what about the backside and inside of the wheel~? Was that trim color or the silver ? (IMG:style_emoticons/default/confused24.gif) Anyone with an surviving OE LE wheel? The inside of the wheels on the LE cars were not painted like the face of the wheels. The insides of the LE optioned wheels were silver. |
al weidman |
Dec 21 2009, 10:59 PM
Al Weidman Group: Members Posts: 156 Joined: 22-February 08 From: Oroville, Ca. Member No.: 8,736 Region Association: Northern California |
914runow is correct, the alloy wheels came with a steel lug bolt with black plastic caps on them and were silver cad plated with a green paint mark. I still have some with the silver cad and the green paint mark. Al. |
Lo-Fi Version | Time is now: 2nd May 2024 - 03:18 AM |
