what did you get done on your teener so far...., this weekend. is teener weekend. |
Aaron Cox |
May 27 2006, 09:01 PM
today:
**pulled the rebuilt carbs. replaced the cold start mech that we pulled that made it run ungodly rich.... ** drained the "gas-o-oil", the oil that got diluted from the super rich condition... ** played with spunone velocity stacks, CAD'd up a drawing for the base plates that i need to have made.... ** fished out valve removal tool for brando.... so he can lap valves and whatnot.... ** applied team narp sticker... ** getting ready for solid black window brow vinyl from zois...... (need a squeegee.....) to be continued. tomorrow... she drives |
bodyman |
May 28 2006, 11:07 AM
Michael Beall Group: Members Posts: 63 Joined: 25-April 06 From: Sand Springs, Oklahoma Member No.: 5,926 |
This weekend Im trying to change the A arm that was bent on my car when I got it, I have it un bolted, But have yet to get it dropped, Its my first front end drop, so Im taking it slow as to not break anything.
Michael |
guiltless |
May 28 2006, 01:16 PM
Member Group: Members Posts: 187 Joined: 7-August 05 From: Dana Point Ca Member No.: 4,552 |
Now that the semester is over, I actually did something.
** Removed Headlight Assy** ** Removed driver side seat** ** Removed all of the wiring** ** Removed the remainder of the hosees, cables and linkage** ** Removed all glass except the windshield** ** Removed the rockers (no rust, yay)** ** Removed both trunks and the engine lid** ** Hopefully will start my build thread tonight** Now the car is ready for a rotisserie so I can get the suspension off. |
Joe Ricard |
May 28 2006, 01:24 PM
Changed out passenger traling arm
which included welding in new studs to the hub putting in new Poly bushings grinding away like a pound of excess weld on the whole trailing arm primed painted arm installed aligned checked fitment of slicks All good to go Then started playing around with braking components got 19mm Mc and two late front calipers mocked up and tested Looking to put them on the rear of the car. I will get new front rotors ready for install later tonight. |
blitZ |
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
Lowered the rear about an inch or so, had some positive camber so a added a few shims to mak it a wee bit negative. Need to lower the front a tad. Rear stays put better in a hard turn.
balljoint |
May 28 2006, 01:33 PM
Filled the gas tank. (IMG:style_emoticons/default/mad.gif) Well, less $$$ than filling up the truck at least. (IMG:style_emoticons/default/smile.gif) And then I rotated the tires......at about 60 mph...a few times over the last two days. (IMG:style_emoticons/default/biggrin.gif)
Woo Hoo (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/piratenanner.gif) |
dinomium |
May 28 2006, 03:48 PM
Git on a chair son, all the good stuff is goin over yer head! Group: Benefactors Posts: 2,777 Joined: 2-January 03 From: Bremerton, WA Member No.: 74 Region Association: Pacific Northwest |
all tuned up and ready to go meet Shane for a (IMG:style_emoticons/default/beer3.gif)
YA! I was about to think I couldnt get any of these running! |
Dr. Roger |
May 28 2006, 04:41 PM
if i wasn't going up to Bethel Island today I'd be fixing my starter. =-)
my other addiction is fast boats...... |
TROJANMAN |
May 28 2006, 04:56 PM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
pulled first gear out
Aaron Cox |
May 28 2006, 06:28 PM
update...
car runs / drives / stops. still tuning carbs.... having a facet pressure issue.... and my regulator is crap.... so it flies on WOT and pulls away fine..... little bog. all is useless without rocksolid fuel prssure..... close.... |
Allan |
May 28 2006, 06:37 PM
!. Reset M/C pin switch.
2. Check Brake fluid (Good). 3. Wash Car. 4. Drive car. 5. Check oil level (Good). 6. Park car in garage. See... Attached image(s) |
Allan |
May 28 2006, 06:38 PM
I violated this rule
Aaron Cox |
May 28 2006, 06:39 PM
2/3 of my 904 gauge is working (IMG:style_emoticons/default/tongue.gif)
got it up to 180.... by romping it around..... 10 bar pressure gauge is still being a beeyotch |
dinomium |
May 28 2006, 06:40 PM
(IMG:style_emoticons/default/drunk.gif)
Now that I am back from scaring the folks in Brownsville, I think I will hook up the driving lights and maybe the stereo... |
Howard |
May 28 2006, 06:54 PM
Incontin(g)ent Member Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None |
Sat: Check oil, TP. Take long way (Mulholland) to Harbor freight to buy stupid star socket set for 911. Buy a bunch more shit I don't need. Take longer way back, stop at Do-It, pick up bag of topsoil mix. Reseed bad spots in back yard. Make Margaritas and watch F1 qualifying. Nice move, Schu!! (IMG:style_emoticons/default/blink.gif)
Sun: EuroSunday with 8 gazillion $$ worth of cars. Didn't even bother taking pix of most of the Ferraris and C-GT's, they're just so common. One orange 914 there, but ???. Mulholland again to PCH and then to Camarillo Airport for brunch with the high rollers. My life sucks (IMG:style_emoticons/default/smile.gif) Tomorrow (IMG:style_emoticons/default/jsharp.gif) Attached image(s) |
Pat Garvey |
May 28 2006, 07:04 PM
Trimmed shrubs. Planted plants. Found out me 911 batteries are dead - what else is new. Cleaned more oil up from underneath the fourteen. Soaked some headlight bezels in vinegar. You know, the regular stuff.
Pat Garvey |
May 28 2006, 07:06 PM
Trimmed shrubs. Planted plants. Found out me 911 batteries are dead - what else is new. Cleaned more oil up from underneath the fourteen. Soaked some headlight bezels in vinegar. You know, the regular stuff. Jeez.....I meant "surrounds" not the F'ing bezels! |
airsix |
May 28 2006, 09:25 PM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
...And I bet you all thought I was dead.
Strike that. ...I bet you all forgot I was alive. (IMG:style_emoticons/default/bye1.gif) Well, a year and a half ago I was compelled to buy a 'sensible' daily driver for work. Shortly thereafter the 914 came down with EFItis. I parked it and didn't touch it until last week. So yesterday I diagnosed the EFI problem - dying battery was not pushing enough voltage to the hall sensors on the crank. There was enough juice to crank the motor but not run the EFI electronics. Battery was hosed, so I picked up another. Then it still wouldn't catch. (IMG:style_emoticons/default/confused24.gif) Couldn't find anything mechanically wrong so started checking the electronics again. Found that somehow my tuning map had been corrupted in the ignition section. Timing between 800-2000rpm was retarded -53 degrees. Well that would explain some of the trouble. Reloaded a 'good' map from the laptop and it fired off on the first crank. Wahooo! Oops. No brakes. Filled & bled the brakes. Checked the tires, oil, brakes again... and then what's this? A fuel leak? These lines are only 4 years old! Replaced a bunch of lines. Ok, finally time to drive. Just a trip around the block (first drive in 18 months). Some of the neighborhood kids actually cheered as I came around the corner yelling "go go go, burnout, floor it". They'd seem me working on it earlier. Once around the corner and out of sight I got a little boost in second. Then I let off the pedal and it stayed on the floor. CRAP! I hit the brakes about the same time it came on full boost (13psi) @ 4,500rpm The fronts locked and it barely slowed down as the motor screamed along at 4k, turbo whining, front tires smoking... I shut it down with the key, stopped, pulled up the pedal, waited as the cloud of smoke rolled past and then fired it up and drove casually home. So much for 'cool'. Definitely have some work to do yet. -Ben M. (not dead) |
grasshopper |
May 28 2006, 09:31 PM
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
Sat: Check oil, TP. Take long way (Mulholland) to Harbor freight to buy stupid star socket set for 911. Buy a bunch more shit I don't need. Take longer way back, stop at Do-It, pick up bag of topsoil mix. Reseed bad spots in back yard. Make Margaritas and watch F1 qualifying. Nice move, Schu!! (IMG:style_emoticons/default/blink.gif) Sun: EuroSunday with 8 gazillion $$ worth of cars. Didn't even bother taking pix of most of the Ferraris and C-GT's, they're just so common. One orange 914 there, but ???. Mulholland again to PCH and then to Camarillo Airport for brunch with the high rollers. My life sucks (IMG:style_emoticons/default/smile.gif) Tomorrow (IMG:style_emoticons/default/jsharp.gif) well you dont have to rub it in (IMG:style_emoticons/default/alfred.gif) |
T H O M A S |
May 28 2006, 09:54 PM
Senior Member Group: Members Posts: 626 Joined: 1-August 03 From: Donaueschingen, Germany Member No.: 974 Region Association: None |
4 hr of BSing with ron
put the rear trailingarms togeter replaced the shiftbushing installed T-fitting |
J P Stein |
May 28 2006, 10:01 PM
Pulled off the rrear cover of the trans ans moved the shift fork about .03-.04 thou.
hope that cures my difficulties. Brit did most of the work while I kept up a steady patter of bullshit....seemed that was the least I could do (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 01:09 AM |
