Targa seals (the expensive ones...), Mittelmotor piece dies... brand new |
Aaron Cox |
May 28 2006, 10:35 PM
redshift |
May 28 2006, 10:40 PM
All my side seals are ruined, and just 2.5 years old..
See, rubber starts to die from the moment it's molded.. it's not MM's fault. M |
GWN7 |
May 28 2006, 11:06 PM
he said he had to strech it to make it fit......
Bleyseng |
May 29 2006, 04:27 AM
I installed a OEM one two years ago and yes they are alittle short. I installed it on a sunny hot day and slowly stretched it out along the windshield top until it reached across then slowly pushed it into place. Then I did the side pieces.
Still leaks abit in a heavy rain at the targa to windshield joint. |
Gustl |
May 29 2006, 06:00 AM
914 enthusiast & historian Group: Members Posts: 11,504 Joined: 16-June 04 From: TIROL / Austria Member No.: 2,212 Region Association: Austria |
back in 2000 I went to a professional restorer to let him do some minor work on my teener (I'm the guy with two left hands (IMG:style_emoticons/default/unsure.gif) )
one of the things was to replace the rubber seals around the top, including this expensive one he decided to buy them from Mittelmotor after installing them he had exactly the same problem, but he thought this would be no problem - well, in my opinion it was a problem ... I mean, this was the reason why I went to a professional he wasn't willing to renew this sh*t, so I asked my lawyer for help result: I went to the local Porsche Center, let them replace all the rubber seals from Mittelmotor and the restorer had to pay the bill (IMG:style_emoticons/default/smilie_pokal.gif) this is the way to get original Prosche seals for the Mittelmotor price (IMG:style_emoticons/default/biggrin.gif) at home I still have some pics from the broken seal - I'll post 'em when I'm back home (I'm at the office now) (IMG:style_emoticons/default/wavey.gif) Gustl |
JeffBowlsby |
May 29 2006, 06:56 AM
914 Wiring Harnesses Group: Members Posts: 8,509 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
They are slightly 'short' so they fit tightly. If installed from one side to the other, it will break every time, do not set it up to fail by stressing the corner joints. I have put this seal on and it works very well if done correctly. Install it in a warm environment. Lube it using soapy water. Press the seal on at the center of the top windshield and work to each side, stretching it slightly as you go. It has memory so when it shrinks...it fits snug.
SLITS |
May 29 2006, 09:00 AM
A hair drier works really neat and put the roof on immediately and let it set for a few days to take a set.....very small tear was the result a few days after roof removal which I filled with RTV. Put it on just before WCC04 and its still there.
Gustl |
May 29 2006, 11:30 AM
at home I still have some pics from the broken seal - I'll post 'em when I'm back home Attached image(s) |
DEC |
May 29 2006, 12:50 PM
Senior Member Group: Members Posts: 630 Joined: 10-November 05 From: Rehburg Member No.: 5,104 Region Association: Germany |
All the MM aftermarket seals have not the the inner reinforcements so they
brokes quicker than the original seals. (IMG:style_emoticons/default/barf.gif) The quality is much worsens. (IMG:style_emoticons/default/mad.gif) That's my opinion. |
jsteele22 |
May 30 2006, 10:23 AM
Senior Member Group: Members Posts: 727 Joined: 24-August 05 From: Colorado Springs, CO Member No.: 4,653 |
I've never done this job, but I wouldn't recommend heating the seal during installation. Unlike "simple" solids, polymers (e.g. rubber) contract when heated. For a piece that is already undersized this would only make the job harder. The linked thread says the manufacturer acknowledged quality control issues, and I also think Jeff Bowlsby's advice is good : install it so that the stress is distributed along the piece, but more at the center than at the corners. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:26 PM |
