914 trivia |
914 trivia |
Dr Evil |
May 29 2006, 12:35 AM
Send me your transmission! Group: Members Posts: 23,000 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
How many places on the 914 can you name where you would use a triple square (12 point) tool?
(IMG:style_emoticons/default/idea.gif) |
elwood-914 |
May 29 2006, 01:16 AM
elwood-914 Group: Members Posts: 387 Joined: 29-December 02 From: Plymouth CA Member No.: 38 |
I think I read in a thread that there was a bolt in the tranny that used it. So my GUESS is 2. But (IMG:style_emoticons/default/WTF.gif) do I know....
thesey914 |
May 29 2006, 01:51 AM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
six flywheel bolt + some CV bolts
Mueller |
May 29 2006, 02:00 AM
impeller/fan on /4 motors
davep |
May 29 2006, 06:19 AM
914 Historian Group: Benefactors Posts: 5,144 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I believe that about covers it.
Dr Evil |
May 29 2006, 06:48 PM
Ha, yup I think we got em all.
There are a few in the tranny CV Flywheel Squirrel cage I thought the tranny ones would trip you up....but since it is me and I am into the tranny things it was probably obvious. |
bd1308 |
May 29 2006, 06:58 PM
(IMG:style_emoticons/default/smile.gif) ....how about the 12 point cap on the left side of the engine for the oil control system?
b |
Dr Evil |
May 29 2006, 10:34 PM
Ah, I think you found another.
Aaron Cox |
May 29 2006, 10:37 PM
the oil pressure relief piston is a way bigger size tho...
a 3/8 ratchet extension (no socket) works great.... |
May 30 2006, 12:57 AM
Triple-squares mount some fans to the fan hub. I think they may be what holds all of the four-cylinder fans together, though.
--DD |
bd1308 |
May 30 2006, 06:40 AM
AA, no size was mentioned.
I knew there was a size difference. b |
fuch toy |
May 30 2006, 07:03 AM
Unregistered |
How about, you pull the door panel to fix a window problem. You put everything back together and now your interior door handle won't open the door.
What did you do wrong? Easy answer if you've done this before. |
May 30 2006, 08:58 AM
BTDT! I switched the window winder and door release screws. Drove me completely nuts finding that one!!!
--DD |
Lo-Fi Version | Time is now: 20th May 2024 - 09:06 PM |
