Dr Evil
May 29 2006, 12:35 AM
How many places on the 914 can you name where you would use a triple square (12 point) tool?
elwood-914
May 29 2006, 01:16 AM
I think I read in a thread that there was a bolt in the tranny that used it. So my GUESS is 2. But
do I know....
thesey914
May 29 2006, 01:51 AM
six flywheel bolt + some CV bolts
Mueller
May 29 2006, 02:00 AM
impeller/fan on /4 motors
davep
May 29 2006, 06:19 AM
I believe that about covers it.
Dr Evil
May 29 2006, 06:48 PM
Ha, yup I think we got em all.
There are a few in the tranny
CV
Flywheel
Squirrel cage
I thought the tranny ones would trip you up....but since it is me and I am into the tranny things it was probably obvious.
bd1308
May 29 2006, 06:58 PM
....how about the 12 point cap on the left side of the engine for the oil control system?
b
Dr Evil
May 29 2006, 10:34 PM
Ah, I think you found another.
Aaron Cox
May 29 2006, 10:37 PM
the oil pressure relief piston is a way bigger size tho...
a 3/8 ratchet extension (no socket) works great....
Dave_Darling
May 30 2006, 12:57 AM
Triple-squares mount some fans to the fan hub. I think they may be what holds all of the four-cylinder fans together, though.
--DD
bd1308
May 30 2006, 06:40 AM
AA, no size was mentioned.
I knew there was a size difference.
b
fuch toy
May 30 2006, 07:03 AM
How about, you pull the door panel to fix a window problem. You put everything back together and now your interior door handle won't open the door.
What did you do wrong?
Easy answer if you've done this before.
Dave_Darling
May 30 2006, 08:58 AM
BTDT! I switched the window winder and door release screws. Drove me completely nuts finding that one!!!
--DD
