Why would carbs keep working out of tune? |
alan9144 |
May 29 2006, 06:12 AM
Newbie Group: Members Posts: 39 Joined: 10-March 05 From: SoCal, previously Scotland, UK Member No.: 3,735 Region Association: Southern California |
At my wits end with this one, I seem to be spending my whole life working on my carbs. Had major problems with them popping at idle, so completely stripped them down and cleaned everything, put new carb to manifold gaskets on, rebuilt them and for a week they were bang on, no misses no flat spots no pops, but now they are back with a vengance (IMG:style_emoticons/default/sad.gif)
Seems to happen all the time set them up and they are fine for a week then all the problems come back!! Any ideas anyone |
Joe Ricard |
May 29 2006, 06:17 AM
YUP, Dirty Idle jets. I have the same problem but seem to have fixed it with some foam insulation around the filter housing cover and base plate.
Another thing I found out was my co-driver was bending the linkage with his big foot. I adjusted the pedal stop to coincide with the throttle stops on each carb. |
JoeSharp |
May 29 2006, 06:38 AM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
Alan: What linkage are you using?
:PERMAGRIN: Joe |
Tom Perso |
May 29 2006, 06:45 AM
Crazy from the Cold... Group: Members Posts: 647 Joined: 8-August 03 From: Kalamazoo, MI Member No.: 1,003 |
(IMG:style_emoticons/default/agree.gif) on both parts.
A big right foot will kill the hex bar alignment. Also, check your gas tank, it may be due for a cleaning. Clean the tank, do all new lines (if needed, but I'd do it) and good filter(s). If you have one of those clear glass type filters, chuck it in the trash. The joys of carbs... (IMG:style_emoticons/default/smile.gif) Tom |
alan9144 |
May 29 2006, 07:00 AM
Yeh its a hex linkage and I have big feet (IMG:style_emoticons/default/biggrin.gif) Never had this problem with my other cars which all run hex linkage on the carbs but I will try these things out. As for filters I have 2, one at the tank a cylinder type, which could be really dirty and one of those clear ones before the carbs.
Will have a look at all this and let you guys know - oh and cheers (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 14th May 2024 - 06:30 PM |
