HELP!! What did I do to my car?, fuses, smoke and other bad things |
biosurfer1 |
Sep 28 2003, 03:10 PM
Teener fo Life! Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
so after working for about a week, the fuse to the dash lights in my car popped again, which i thought was a little weird to happen so fast, but i replaced it and the replacement popped too. I had just bought some of the original type fuses on ebay (was using the tube fuses) so i thought i'd throw one of those in, that when the trouble started. I had the dash lights turned all the way down, after i replaced the fuse, i slowly turned them up and before i knew it, there was a lot of smoke bellowing up from behind the fuse panel. I quickly turned them off, and took apart the panel to look at the damage, to which i couldnt find anything, so it must have been in one of the relays. the new fuse did not pop, and i dont understand why, it was the correct amperage, i double checked. so does anyone know what i could have done, or where to start checking to find out?? HELP!! this is driving me crazy, not to mention i have no dash lights...
3d914 |
Sep 28 2003, 03:42 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
bio,
Have you made any upgrades to the lights recently - like 100w headlights? Any other electrical-related mods? If not, then you're likely correct on the relay. Its not a bad idea to pick up a couple to have for spares - they're alll the same. Just don't forget to put them in the glove box. I always end up leaving my spares on the work bench - and go without on the road. Keep us posted. |
biosurfer1 |
Sep 28 2003, 03:58 PM
where can i get the relays?
Sep 28 2003, 04:12 PM
QUOTE(biosurfer1 @ Sep 28 2003, 02:58 PM) where can i get the relays? order them online. all the usual places have them. they also carry the original fuses. no need to pay overprice on ebay (IMG:style_emoticons/default/wink.gif) Andy |
Lo-Fi Version | Time is now: 21st May 2024 - 05:40 PM |
