making 914 Konis fit into 911 Boge struts |
East coaster |
Jun 4 2006, 09:36 PM
Senior Member Group: Members Posts: 1,672 Joined: 28-March 03 From: Brigantine, NJ Member No.: 487 Region Association: None |
I started putting my suspension bits together this weekend. I've been bead blasting, painting and assembling. I have an '85 Carrera front end with boge struts and I had a set of 914 Koin reds (adjustable) that I wanted to use. Unfortunately, they don't just bolt in. I machined up some step spacers that allow the Koni to be used with the Boge struts.
The Konis have a step at the top of the cartridge and will swim in the Boge cap. Here's a pic of the Koni top: Here's a pic of the spacer I machined up. It sits on top of the insert and the outer diameter is a perfect fit to the strut cap. |
East coaster |
Jun 4 2006, 09:38 PM
Spacer installed on insert
Cap installed and complete |
East coaster |
Jun 4 2006, 09:41 PM
Here's the rest of the suspension bits post blasting/painting and ready to bolt on. I just need to clean and repaint the trailing arms and I'm good to go!
Lo-Fi Version | Time is now: 16th May 2024 - 06:21 PM |
