timing bar/arc |
timing bar/arc |
tod914 |
Jun 5 2006, 08:12 AM
When I first got my 75, it had this timing bar/indicator by the fan shroud somewhere. It's white with a red mark at 27 degrees. Was this original to the car? When I had the car serviced after I first picked it up, the mechanic removed that along with the air pump system. Does anyone know where this timeing mark indicator mounts?
JeffBowlsby |
Jun 5 2006, 08:23 AM
914 Wiring Harnesses Group: Members Posts: 8,485 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
tod914 |
Jun 5 2006, 09:27 AM
Here you go. been trying to see where it mounts.. none of the screw/bolts on the shroud seem to accomodate both fittings.
tod914 |
Jun 5 2006, 03:42 PM
Ok Jeff, its posted
JeffBowlsby |
Jun 5 2006, 05:14 PM
I have never seen anything like that before, but I have not seen everything. Anyone else? I am not even sure where it would mount for it to be useful, maybe on the front facing shroud by the fan cage?
tod914 |
Jun 5 2006, 05:32 PM
I was thinking either the zero mark or the 27 mark is aligned with the hole in the top of the fan shroud/timing mark. but i cant seem to find a spot for both holes to mount too. maybe ill put back on some of the old airpump brackets and see if that works better for mounting it.
Pat Garvey |
Jun 5 2006, 06:00 PM
I have never seen anything like that before, but I have not seen everything. Anyone else? I am not even sure where it would mount for it to be useful, maybe on the front facing shroud by the fan cage? Wow, it'd b a BIG help, but I've never seen one of these either! How the heck would it mount? Wouldn't want it to be off even a half degree. |
RustyWa |
Jun 9 2006, 10:07 PM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
My '75 had one as well. I thought I had a picture of it, but can't seem to find it. If you do a search in the garage, you might be able to find my post about it.
If you are looking in the engine bay, it is located on the passenger side of the impeller opening. Can't remember if it was on the upper half or lower half. There was another timing mark on the outer pulley ring. It didn't make it any easier to time the car as you needed a mirror to see it. |
RustyWa |
Jun 9 2006, 10:15 PM
I found the link, it was over at Pelican. The photo was a close up on my old cheapy camera, but you can see the mark on the alternator belt "ring".
http://forums.pelicanparts.com/showthread....&threadid=69581 |
tod914 |
Jun 10 2006, 07:15 AM
Thanks Rusty, was trying to figure out where it went. When we tried to time it when I first got it, the mechanic had to set the timing mark. Only indicator was top dead center "0". I'll see if I can figure out how its attached now.
tod914 |
Jun 10 2006, 01:56 PM
Still an enigma.. dont see any attachments points.. Do you recall where it mounted to by chance?
RustyWa |
Jun 10 2006, 07:05 PM
I think it attaches to these points in the following way... My photo editing skills are not as good as others. (IMG:style_emoticons/default/biggrin.gif)
Attached thumbnail(s) |
RustyWa |
Jun 10 2006, 07:18 PM
The posts it attaches to...
tod914 |
Jun 10 2006, 07:45 PM
Excellent now I see how the coil mounts to the shroud as well. Thanks!
RustyWa |
Jun 10 2006, 08:35 PM
Lo-Fi Version | Time is now: 1st May 2024 - 01:55 PM |
