Spring is Sprung, The Grass is Riz,, And the rear end of my car is as crooked as a.......... |
balljoint |
Jun 5 2006, 11:18 AM
914 with a ride height 1.5" shorter on the passenger side at the wheel well.
Does that rhyme? New springs and the problem is solved right? 100-140 lb? Are there a number of different manufacturers that make springs that happen to be the correct size and I should just poke around or is there a preferred manufacturer (or un-preferred). Also, and in addition, I happen to have a brand-spankin' new set of Koni Yellows that came with the '71, never installed. Is there any difference from the '71 to the '74 as far as the rear shocks go? Gracias in advance Chicos and Chicas, |
Lo-Fi Version | Time is now: 17th May 2024 - 03:27 AM |
