speedometer cable replacement |
jimtab |
Sep 28 2003, 11:22 PM
Advanced Member Group: Members Posts: 3,477 Joined: 5-January 03 From: Pacifica, California Member No.: 91 Region Association: Northern California |
OK, I give up. How the hell does a person with big hands get the cable re-attached to the back of the speedometer? I sure as hell can't get at it from the hole below the dash. I also can't seem to get enough slack in the cable to re-attach it after taking the plate with the three (speedo, tach, combo) loose and pull it forward. Do I need to detach it at the trans and get the slack there? Do I obtain a small child with small, strong hands and force them to do the job. Come on gang, share the wisdom....I need help. By the way, how was the Hooters nite...I hated to miss it and the last 914 breakfast but the teener is having some shifting issues. Jim
ChrisReale |
Sep 28 2003, 11:44 PM
its tough, but you can remove the gauge cluster by unscrewing the four screws, and popping it out...
jimtab |
Sep 29 2003, 08:24 AM
QUOTE(ChrisReale @ Sep 28 2003, 09:44 PM) its tough, but you can remove the gauge cluster by unscrewing the four screws, and popping it out... Like I said, even after removing the guage cluster I couldn't get enough slack in the cable to get it hooked up. |
markb |
Sep 29 2003, 03:21 PM
I never pull the whole cluster, I just pull the speedo forward & set it on the steering column. You may still wind up having to have a small-handed person screw in the cable. Mark (sometimes thankful for small hands (IMG:style_emoticons/default/wink.gif) )
Sep 29 2003, 04:39 PM
loosen the clamps that hold the cable to the front firewall, that'll give you enough slack.
the cable comes out of the center tunnel and then runs up the front firewall to the gauge, alongside the steering column. it's hold in place by a few clips/clamps ... might be behind carpet, dunno, it's been so long since i had carpet in my car (IMG:style_emoticons/default/rolleyes.gif) Andy |
ChrisReale |
Sep 29 2003, 05:22 PM
Sorry, I mis-read your orig. post. I just put mine in, it was a tight fit for my hands, and it was a PITA, but I got it in...
ss6 |
Sep 29 2003, 07:58 PM
fun city... Group: Members Posts: 261 Joined: 2-February 03 From: Western Connecticut Member No.: 221 |
Just had the speedo out, with a little patience and strong fingers you can pull the tach out of its hole and gain a nice hand access hole to the %^$@# speedo cable.
Mine snapped recently after I rotated the speedo to see the important numbers (30 - 100) thru the Momo steering wheel. Anybody want to know how to rig an electronic 911 speedo for a teener? |
jimtab |
Sep 29 2003, 10:36 PM
Thanks for the input guys, I think if I get some slack in the cable I can beat the thing into submission. Sometimes it's hard to be a "well hung" lesbian. Jim (IMG:style_emoticons/default/lol3.gif) And....if that doesn't work.... (IMG:style_emoticons/default/smash.gif)
Qarl |
Sep 29 2003, 10:40 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
VDO makes an adapter that fits on the end of the speedo cable that outputs a signal that the electronic gauges can read. Don't know if anyone has actually tried it! |
Sep 29 2003, 10:41 PM
QUOTE(jimtab @ Sep 29 2003, 09:36 PM) Sometimes it's hard to be a "well hung" lesbian ... i'm trying to picture you, gawd, i'm in tears (IMG:style_emoticons/default/laugh.gif) |
Sep 29 2003, 10:42 PM
QUOTE(kellzey @ Sep 29 2003, 09:40 PM) VDO makes an adapter that fits on the end of the speedo cable that outputs a signal that the electronic gauges can read. or even better, get a 915 gearbox! |
914Timo |
Sep 30 2003, 04:20 AM
******* Group: Members Posts: 743 Joined: 13-January 03 From: Finland Member No.: 137 Region Association: Europe |
QUOTE Posted on Sep 30 2003, 07:40 AM Anybody want to know how to rig an electronic 911 speedo for a teener? VDO makes an adapter that fits on the end of the speedo cable that outputs a signal that the electronic gauges can read. Don't know if anyone has actually tried it! I would like to know. Do you have any part number for that VDO adapter ?? That sounds interesting. Are you going to use one ??? I |
Jeffs9146 |
Sep 30 2003, 10:18 AM
I just pop out the tach and reach in the tach hole to screw on the cable! Wasn't that tough! (IMG:style_emoticons/default/clap56.gif)
Jeff |
Lo-Fi Version | Time is now: 21st May 2024 - 12:51 PM |
