"Minor" Carburator Trouble, Why doesn't this car run very well? |
McMark |
Sep 29 2003, 04:21 AM
One of the cars at Brad's shop wasn't running very well. After checking the obvious stuff we took the carbs off the engine and tore them down. Holy cow!
McMark |
Sep 29 2003, 04:22 AM
Closer detail
McMark |
Sep 29 2003, 04:23 AM
More
McMark |
Sep 29 2003, 04:24 AM
The carb cover had a broken pivot from a previous botched rebuild.
McMark |
Sep 29 2003, 04:25 AM
This is what it should look like.
McMark |
Sep 29 2003, 04:26 AM
Here's the driver side fuel bowl.
McMark |
Sep 29 2003, 04:27 AM
Detail.
McMark |
Sep 29 2003, 04:28 AM
And finally, here's one of the MANY clogged jets. There shouldn't be that tip sticking out the end.
rhodyguy |
Sep 29 2003, 06:36 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,081 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
i'm surprised it ran at all. that metering devise sticking out of the main jet stack looks like a tooth pick. all others aside what's the fix for the broken pivot? the aluminum recycler?
kevin |
seanery |
Sep 29 2003, 07:00 AM
I have a feeling those are mine!
rhodyguy |
Sep 29 2003, 07:11 AM
really? he said your engine started, idled and ran well. just was a little noisy (valve train?). the engine with those carbs must have snapped, popped, farted... . i can't imagine brad throwing those carbs on your brand spanking new motor without checking them out first. i'd like to see a shot of the fuel filter.
kevin |
seanery |
Sep 29 2003, 07:13 AM
i don't know, when we got it to the shop, it was very clogged up. So, it's likely that it was mine.
rhodyguy |
Sep 29 2003, 07:27 AM
i should think your phone would've been ringing off the hook if those were yours. worst case, there is a set of "new"in the classifieds for what seems to be a pretty fair price. "that's the way the money goes, pop, goes the weasel"
kevin |
seanery |
Sep 29 2003, 07:32 AM
we'll see. Brad usually fixes the trouble then says "You know those....They were yours"
I'll call him today and see. |
rhodyguy |
Sep 29 2003, 07:39 AM
i should think he'll be loading the trailer for the trip back east today. i did'nt send the stickers to you. i did a calander check. not enough time before you fly out without sending them next day air. too exspensive.
kevin |
rhodyguy |
Sep 29 2003, 07:44 AM
i wonder if the piece from the float pivot was in the bottom of the bowl.
kevin |
McMark |
Sep 29 2003, 09:42 AM
No metal piece on the bottom of the bowl. Obviously it's been that way for awhile. You can get a new cover plate, there is no good fix for a broken pivot.
seanery |
Sep 29 2003, 10:05 AM
mark, is it my car?
Brad Roberts |
Sep 29 2003, 11:53 AM
It was yours. I didnt check them because the anemic engine actually ran pretty good.. it just needed more cam. This one fired up and idled/ran fine. I found the problem the first time I wrapped it up to 6500 in 4 gears getting on the freeway for a test run.. it started running on 2 cylinders.. quickly limped it back to the shop and found the idle jets clogged.. then pulled them apart and found this. It will have to run with the broken float do-hickey. I dont feel that it is an issue right now.. but it will have to be addressed and I dont have time to order one.
I hate FUCKING carbs. Add 8 hours to your bill. Carbs only took an hour.. it was all the other "small stuff". LIke throttle linkage... return springs... air cleaner studs...carb tuning (after cleaning). I still have to install the heater fan and the small air tubes. It runs STRONG. Puts you back in the seat pretty damn good. B |
seanery |
Sep 29 2003, 12:02 PM
Express mail package was not delivered on Saturday. They will do it today. Also, I sent out those Utabs last week. Should have arrived on Thursday or Friday.
Lo-Fi Version | Time is now: 21st May 2024 - 09:00 PM |
