> Front hood alignment, the buckled look
boxsterfan
post Sep 29 2003, 11:23 AM
914's are kewl
My friend and I were comparing our 914's this weekend (his is a driver and mine is on jacks in the garage). We noticed that both of our front hoods seem to sit above the fender line. So, we took a look at some 914 pics on the internet and saw that some 914's also had this feature.
So, what typically causes the front hood to ride above the fender line?
redshift
post Sep 29 2003, 11:28 AM
Bless the Hell out of you!
You mean the slight arch from front to back, usually worse on the passenger side?
Years of drooping over a gas nozzle, and being opened, and closed.
M
markb
post Sep 29 2003, 03:17 PM
914less :(
And the fix would be.....?
Don't tell me, replace the hood, right?
redshift
post Sep 29 2003, 03:28 PM
It's bent, you have to unbend it, which is actually bending it again. Let me give you a pointer: Don't UN-DO it by pushing up while it's open. (IMG:style_emoticons/default/smile.gif)
I think you need to remove it, and turn it upside down in a buck that is slightly less curved than the original profile, and then clamp the edges, and tighten them a little at a time, test fit, and repeat as needed.
I think this is another one of the cases you would maybe use a little heat also, but not a hammer.
(IMG:style_emoticons/default/wink.gif)
M
post Sep 29 2003, 04:41 PM
Resident German
or get someone to help ...
one presses down on the hood near the windshield, so you don't put pressure on the hinge mechanism while the other un-bends the hood.
it's actually really easy, just go slow, otherwise you'll need a new paint-job.
Andy
- Lo-Fi Version Time is now: 30th June 2025 - 10:15 PM
