Trunk putty? |
Trunk putty? |
1970 Neun vierzehn |
Jun 7 2006, 07:09 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
Not having looked under the rear trunk pad of an early 914 recently(if at all), I've often wondered about the little areas in my rear trunk that seem to be filled/covered/applied with a black, pliable substance that has the consistency of.....putty? Determining whether to repaint the original paint and finish of what is otherwise a reasonably preserved trunk has me wondering if leaving the trunk "original" as finished by the factory might be better than refinishing and spraying it over.
Pat Garvey |
Jun 7 2006, 07:29 PM
Not having looked under the rear trunk pad of an early 914 recently(if at all), I've often wondered about the little areas in my rear trunk that seem to be filled/covered/applied with a black, pliable substance that has the consistency of.....putty? Determining whether to repaint the original paint and finish of what is otherwise a reasonably preserved trunk has me wondering if leaving the trunk "original" as finished by the factory might be better than refinishing and spraying it over. (IMG:style_emoticons/default/icon_bump.gif) It WAS painted by THE FACTORY & apparently some of it has chipped off - that's all. The "putty" is actually a weld seamer & is paintable. We all have it - nothing unusaual, but good thing to bring up - Paulie! |
Pat Garvey |
Jun 7 2006, 07:32 PM
By the way, I forgot to mention that your is a pretty remarkable rear "boot" for a '70. How's that for a "nice" thing to say? Oh, by the wat too bad about the........................................................., just kidding! You are sooo sensitive! |
Jun 7 2006, 07:49 PM
I find it difficult to believe that this material was ever painted. If it had been, I'd suspect that there would've been miniscule paint particles embedded in this soft, pliable material. In the 30+ years I've had this car, I've never seen evidence of paint on this "putty". Since it is beneath the carpet mat for the most part, it has been protected from that which has been put in the rear oven(trunk). And if it were a seam sealing material, why is it just in a few, minor spots? Looking at the photo, you can see where the factory had swathed certain areas of the trunk with some sort of thick, irregular application of ........what? Mastik, caulk, resin hardener?
Pat Garvey |
Jun 7 2006, 07:54 PM
I find it difficult to believe that this material was ever painted. If it had been, I'd suspect that there would've been miniscule paint particles embedded in this soft, pliable material. In the 30+ years I've had this car, I've never seen evidence of paint on this "putty". Since it is beneath the carpet mat for the most part, it has been protected from that which has been put in the rear oven(trunk). And if it were a seam sealing material, why is it just in a few, minor spots? Looking at the photo, you can see where the factory had swathed certain areas of the trunk with some sort of thick, irregular application of ........what? Mastik, caulk, resin hardener? OK, you won't believe me so I'll leave to the experts. Please people, chime in here! |
sixerdon |
Jun 7 2006, 08:06 PM
Member Group: Members Posts: 466 Joined: 23-May 03 From: Dartmouth, MA Member No.: 731 |
I've got the same issue with one of my sixes. 1970 model as yours is. It's a rubberized seam sealer the factory applied before painting. It's been discussed frequently in the "garage" whenever someone wants to remove it. It has to be ground off. I think Eastwood sells the stuff. Brushed on application. Mine hasn't changed over 16 years so I'm leaving it alone. Every 914 has a different look to it. Some workers were sloppy with it and got it everywhere before they painted.
Don |
Jun 8 2006, 08:22 AM
No, all the painted material in the trunk is clean, solid and rock hard. Those half-dozen or so, small black "spots" that you see in the trunk are a soft pliable material that appear never to have been painted. The heavy, "brushed" on material that you see painted is as hard as the metal in the trunk. This black stuff has never been hard and never been painted.
tod914 |
Jun 8 2006, 10:26 AM
Why not just remove the black stuff and see if there is paint under it?
Ferg |
Jun 8 2006, 10:27 AM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
What's your vin #... I've found that the very early cars used a different type of seam sealer in the trunks along the seams, and it was MORE plyable and softer than the later cars, and it also looks like it was squezed out of a toothpaste tube, vs sprayed from a gun on the later cars.
I just inspected a very early 12/69 build date car that confirmed this, compared to my 71. On the car I inspected the same thing, in places paint missing and I could squish it with my fingers. Ferg |
Jun 8 2006, 10:49 AM
Ferg,
Yes, you understand. (IMG:style_emoticons/default/clap56.gif) v.i.n. #4702903114 Blt 01.70. You understand that this is not the stuff that's slathered around the various manufacturing openings that on the early cars looks like its been applied with a brush. On later cars, this sealer, as its been called, looks as if its been applied with a pressure spray applicator. Your description that it appears to be squeezed out of a tube is correct. What's its purpose? If it's supposed to be seam sealer, why didn't the factory use the same stuff that's hardened and painted over as seen in the first picture? |
BS Chairman |
Jun 8 2006, 10:57 AM
Member Group: Members Posts: 98 Joined: 27-December 02 From: Southeast Michigan Member No.: 28 |
No, all the painted material in the trunk is clean, solid and rock hard. Those half-dozen or so, small black "spots" that you see in the trunk are a soft pliable material that appear never to have been painted. The heavy, "brushed" on material that you see painted is as hard as the metal in the trunk. This black stuff has never been hard and never been painted. 1970 Neun vierzehn, I'm and old "Factory Rat" that started at Fisher Body in 1965 Pontiac with the GTOs in the Trim shop. I was and AR who did your job when you missed a day. But, when all worked ARs were loan out to the paint shop. I spend a lot of there on the seal lines. The black rubber that you say was never painted I believe was, as it was appiled to all seams before painting, as was the hard sealer. If you are the first owner I would think that at dealer prep the paint was knocked off before delivery. I can't see Porsche or VW (which one you chose) QC allowing that to leave their plant with paint missing. I looked in my trunk and the rubber is also soft if push on, but, the paint is in tack! So that sealer never sets up I guess we can say. Gary PS If you look under the carpet of some GTOs you might find "GS" (IMG:style_emoticons/default/beer.gif) in hard sealer! |
Jun 8 2006, 12:36 PM
Talk about serendipity! A guy who used to work for PORSCHE(in distribution)walks into my office, we start talking, the conversation drifts off into car restorations and then I show him the trunk photos of my car. Now he worked for PORSCHE after 914 production ceased, but is familiar with the cars and some basic mfg techniques. He sez that after the car is all but finished, the QC guys go over it. If they weren't completely satisfied with body seals, they'd squeeze some pliable sealant out of a tube in the appropriate places. He sez that at this point, the car is far past paint application and most, if not all the trim, is in place. Since the area in question is/will be ultimately covered with a carpeted trunk mat, no effort need be expended to cover the few sealed points. That would explain why there is no trace or evidence whatsoever that this sealant was ever painted over. I believe I will NOT repaint the trunk area.
Pat Garvey |
Jun 8 2006, 07:41 PM
Talk about serendipity! A guy who used to work for PORSCHE(in distribution)walks into my office, we start talking, the conversation drifts off into car restorations and then I show him the trunk photos of my car. Now he worked for PORSCHE after 914 production ceased, but is familiar with the cars and some basic mfg techniques. He sez that after the car is all but finished, the QC guys go over it. If they weren't completely satisfied with body seals, they'd squeeze some pliable sealant out of a tube in the appropriate places. He sez that at this point, the car is far past paint application and most, if not all the trim, is in place. Since the area in question is/will be ultimately covered with a carpeted trunk mat, no effort need be expended to cover the few sealed points. That would explain why there is no trace or evidence whatsoever that this sealant was ever painted over. I believe I will NOT repaint the trunk area. (IMG:style_emoticons/default/WTF.gif) Why? And, how far do plan on going with your restoration? If you're going to get deep into it, why not respray the trunk, engine compartment, front trunk? Or is the restoration only a partial? What's your goal? By the way, now that you have a high-grade digital camera, how about a close-up of one of these post-paint sealant spots? |
sixerdon |
Jun 8 2006, 08:34 PM
Yes, I agree. Some close up pictures if you can. One of my sixes has a 01/70 build date. The other 03/70.
BTW Paul, did your car come with or without the rubber shock covers? I don't know if you are the O.O. Don |
Jun 9 2006, 06:30 PM
Don,
I bought #4702903114 in July 1975 from the original owner who took delivery in Jan. 1970. I've got the original burgundy service book. The car, w/appearance group, did not have fog lights from the factory, they were dealer installed. It did not have rear shock covers, nor was it delivered with the tethered foot rest, allthough the "ring" is there. It did have the vinyl covered roll bar, chrome bumpers and leather covered s/w. |
sixerdon |
Jun 9 2006, 07:51 PM
Don, I bought #4702903114 in July 1975 from the original owner who took delivery in Jan. 1970. I've got the original burgundy service book. The car, w/appearance group, did not have fog lights from the factory, they were dealer installed. It did not have rear shock covers, nor was it delivered with the tethered foot rest, allthough the "ring" is there. It did have the vinyl covered roll bar, chrome bumpers and leather covered s/w. Thanks Paul, I've always been curious whether the very early cars came with the rubber shock covers as mine were not there 16 years ago. My six also did not have the circuit board cover like many early photo's show. It has one now. A worn foot rest was with the car. I have also heard that the fog lights were not available for the first 500 or so sixes which would bring the build date through Feb '70. Now here's another question for you. If you have the original front carpets, do they have the button holes? My original carpet does not. No buttons on the floor to secure the carpet. Seems Karmann didn't add that until March. Don |
Jun 10 2006, 08:34 AM
Don,
Though the picture doesn't show the entire carpet area, the carpeting is original and there is no hole(s) in them. Attached thumbnail(s) |
sixerdon |
Jun 10 2006, 08:54 AM
Paul,
Good to know. Those button holes would be in the rear corner of the carpets just in front of the cross member. You'll have to see a later model to see the difference. Your car and my car #0137 are the same color with similar Karmann details. I've been told by a mechanic who worked on it 36 years ago that it was the first six sold in New England. Don |
Jun 7 2007, 06:15 PM
Well, this thread is almost a year old now, and here's what is being done about the "trunk putty" dilemma.......
BS Chairman |
Jun 7 2007, 08:26 PM
Paul, please tell us that you are putting new sealer back on to match the old. Your car looks like it's coming along. When do you hope for paint?
Gary |
Lo-Fi Version | Time is now: 29th April 2024 - 11:10 AM |
