Color Of Sound Deadening Pad Clips |
AvalonFal |
Jun 8 2006, 07:35 AM
Member Group: Members Posts: 483 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region |
OK, in my obsession to get every little clip and bracket the "correct" color, what is the consensus for the clips that hold the sound deadening pad in place on the rear firewall ('74 2.0L)? They run across the firewall top and I also have them down the sides. Currently they are body color above the pad and black (satin) where the clip holds the pad.
Also, I assume that none of these clips had the vinyl covering like the electrical wiring clips do. Finally, anybody know if those vinyl coverings are available new or can be made somehow?? |
Pat Garvey |
Jun 9 2006, 03:37 PM
Do I or don't I...........? Group: Members Posts: 5,899 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States |
OK, in my obsession to get every little clip and bracket the "correct" color, what is the consensus for the clips that hold the sound deadening pad in place on the rear firewall ('74 2.0L)? They run across the firewall top and I also have them down the sides. Currently they are body color above the pad and black (satin) where the clip holds the pad. Also, I assume that none of these clips had the vinyl covering like the electrical wiring clips do. Finally, anybody know if those vinyl coverings are available new or can be made somehow?? (IMG:style_emoticons/default/drooley.gif) No help w/the sound deadening clips, but I wonder why proper sized heat shrink tubing wondn'y work for the appropriate clips? Cut a length, slip onto the clip & hit it w/a heat gun/hair dryer. Has to look about the same & I'd bet the original parts are NLA. |
spunone |
Jun 9 2006, 04:14 PM
Senior Member Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California |
Might want to try Plastidip stuff they use to dip tools for the handles or liquid electrical tape several coats What ya think
TJB/914 |
Jun 9 2006, 06:53 PM
Mid-Engn. Group: Members Posts: 4,327 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest |
Hey guys,
I remember something from my restoration regarding those vinyl covers. The ones on my car were a little on the hard side with lots of grunge, etc. I took all I could find from my parts car along with the ones off my car & soaked them overnight in carb cleaner. They cleaned up beautiful and became soft and plyable. Today they still feel soft & plyable and look like new. The material is tough vinyle or PVC. Try one or two & see if it works for you. If I remember correctly all the metal tabs were body color??? Only 98% sure??? Makes sense the factory painted all metal tabs because it's attached to the body. Tom |
914werke |
Jun 9 2006, 10:53 PM
"I got blisters on me fingers" Group: Members Posts: 10,066 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Ive been at this latley, I saved all the wire covers off of a few cars
Ive parted, I just dumped them in a tub of 1to1 solution of Castrol superclean and hot water. Left overnight ...same result clean and plyable once again. They seem to come in two hues, a dark grey and black. and not were used on the tabs holding in the backpad. |
GWN7 |
Jun 10 2006, 08:49 AM
King of Road Trips Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region |
Sound deading: body color on a 74 (just took the pad off the 74 parts car) Plastic holders: get them off parts cars |
Lo-Fi Version | Time is now: 17th May 2024 - 08:07 PM |
