EEETTTTSSSS AAAALLLLLLLIIIIIVVVVEEEEE, and flyin! |
Aaron Cox |
Jun 8 2006, 10:05 PM
long story about the down time on my car....
something along the lines of "smaller venturi's and raby jetting suggestion" to optimize performance.... blah blah blah... remove cold start stuff like a few guru's said... "why is it dumping 8 gallons of fuel down each throat" blah blah blah.... call brad... put cold start pistons back in... and finish the carb rebuild.... anyway. so last weekend had the car close.... but my lame dial fuel regulator croaked... and was spitting fuel out the accedl jets at "3" PSI... but falling on its face at 2.5.... Problem solved. KaptKaos sold/traded me a CB rotary internal regulated pump... car idles great. starts up first crank. roll onto throttle, idle circuits werkin bitchin, and i was getting a little hesitation onto main tranisiton but would do OK at WOT..... up the main jet to a 135 from a 130 and it is BADASS.... totally smooth thru the powerband, no smoke, no hiccups, backfires or coughing..... runs AWESOME. i am soooo stoked. car flies. lit up the 8" fuchs wrapped in yokohamas like butta LOL..... i have a slight crack in a header weld and need to fix it.... gotta throw in the short geared tranny... and go fight some electrical gremlins, and i am good to go... my dad liked the second gear chirp LOL AA |
TROJANMAN |
Jun 8 2006, 10:10 PM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
Holy Crap.............Did you see that .........................?......................
wait........ There it is (IMG:style_emoticons/default/biggrin.gif) (good job aaron (IMG:style_emoticons/default/clap56.gif) ) Attached image(s) |
jd74914 |
Jun 8 2006, 10:11 PM
Aaron, do you have a list of your entire engine formula/specs list
BigDBass |
Jun 8 2006, 10:13 PM
Dumb Question Champion Group: Members Posts: 1,438 Joined: 11-January 06 From: Chicago (south 'burbs) Member No.: 5,405 Region Association: Upper MidWest |
Aaron Cox |
Jun 8 2006, 10:14 PM
blah....
see if i can remember... 71x94 2L 8.5 ish compression Eurorace header Big cam.... Mallory CDI box, Unilite Dizzy, and CDI coil on the firewall.... 2L heads, with SS valves, big springs, and stock valve sizes.... 38mm oil pump, front cooler, mocal thermostat, setrab cooler... weber 44's, 34 vents, 50 idles, 175 airs, 135 mains.... stock gear box as of now.... have my A F ZDFlip S ZD bpx to go in.... |
BigDBass |
Jun 8 2006, 10:15 PM
QUOTE have my A F ZDFlip S ZD bpx to go in.... There you go with speaking code again.... |
Hammy |
Jun 8 2006, 10:17 PM
QUOTE have my A F ZDFlip S ZD bpx to go in.... There you go with speaking code again.... (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/screwy.gif) |
Aaron Cox |
Jun 8 2006, 10:21 PM
sorry... gear ratios LOL
jd74914 |
Jun 8 2006, 10:23 PM
blah.... see if i can remember... 71x94 2L 8.5 ish compression Eurorace header Big cam.... Mallory CDI box, Unilite Dizzy, and CDI coil on the firewall.... 2L heads, with SS valves, big springs, and stock valve sizes.... 38mm oil pump, front cooler, mocal thermostat, setrab cooler... weber 44's, 34 vents, 50 idles, 175 airs, 135 mains.... stock gear box as of now.... have my A F ZDFlip S ZD bpx to go in.... Cool. If my tranny chart here is right that looks like a nice short AX tranny (IMG:style_emoticons/default/happy11.gif) |
Aaron Cox |
Jun 8 2006, 10:24 PM
blah.... see if i can remember... 71x94 2L 8.5 ish compression Eurorace header Big cam.... Mallory CDI box, Unilite Dizzy, and CDI coil on the firewall.... 2L heads, with SS valves, big springs, and stock valve sizes.... 38mm oil pump, front cooler, mocal thermostat, setrab cooler... weber 44's, 34 vents, 50 idles, 175 airs, 135 mains.... stock gear box as of now.... have my A F ZDFlip S ZD bpx to go in.... Cool. If my tranny chart here is right that looks like a nice short AX tranny (IMG:style_emoticons/default/happy11.gif) very good son, with a stock 5th for cruising.... (have to wind out 4th to be in the power band for 5th tho....) |
So.Cal.914 |
Jun 8 2006, 10:49 PM
[quote name='Aaron Cox' date='Jun 8 2006, 09:24 PM' post='699158']
[quote name='jd74914' post='699155' date='Jun 8 2006, 09:23 PM'] [quote name='Aaron Cox' post='699148' date='Jun 9 2006, 12:14 AM'] [/quote] with a stock 5th for cruising.... (have to wind out 4th to be in the power band for 5th tho....) [/quote] Have to wind out 4th, bet that will break your heart. Sounds nice... |
Aaron Cox |
Jun 8 2006, 10:50 PM
3rd at 6k is about 65....
4th at 6k is 90 (IMG:style_emoticons/default/smile.gif) 90 in 5th is about 4200 rpm (IMG:style_emoticons/default/smile.gif) im set LOL |
Trekkor |
Jun 8 2006, 10:58 PM
Great job!! (IMG:style_emoticons/default/clap56.gif)
Now come up here so I can work you over at the a/x (IMG:style_emoticons/default/ph34r.gif) KT |
Aaron Cox |
Jun 8 2006, 10:59 PM
3rd at 6k is about 65.... 4th at 6k is 90 (IMG:style_emoticons/default/smile.gif) 90 in 5th is about 4200 rpm (IMG:style_emoticons/default/smile.gif) im set LOL fine.... A F flipped ZD S and ZD enjoy (IMG:style_emoticons/default/smile.gif) Attached image(s) |
Aaron Cox |
Jun 8 2006, 11:00 PM
Great job!! (IMG:style_emoticons/default/clap56.gif) Now come up here so I can work you over at the a/x (IMG:style_emoticons/default/ph34r.gif) KT i never said i could drive!!! HAHHAHAHAH (IMG:style_emoticons/default/ph34r.gif) |
rick 918-S |
Jun 8 2006, 11:02 PM
Hey nice rack! -Celette Group: Members Posts: 20,462 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
dinomium |
Jun 8 2006, 11:36 PM
Git on a chair son, all the good stuff is goin over yer head! Group: Benefactors Posts: 2,777 Joined: 2-January 03 From: Bremerton, WA Member No.: 74 Region Association: Pacific Northwest |
Congrats man! Drivin is better than wrenching, at least I think it is!
Rand |
Jun 8 2006, 11:42 PM
Congrats AAron. Great news!
(IMG:style_emoticons/default/boldblue.gif) (IMG:style_emoticons/default/burnout.gif) (IMG:style_emoticons/default/clap56.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/thumb3d.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/monkeydance.gif) (IMG:style_emoticons/default/wreath.gif) Hey wait, where'd that last one come from? (IMG:style_emoticons/default/beerchug.gif) |
sherman1 |
Jun 9 2006, 12:07 AM
Team McLaren Group: Members Posts: 57 Joined: 10-March 06 From: Woodside, CA Member No.: 5,697 |
No kidding, very impressive.....we (most of us anyway) are not worthy! (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/thumb3d.gif) |
TonyAKAVW |
Jun 9 2006, 12:31 AM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
Congrats!!!
Thats a big accomplishment... Lots of work into that car. Looks and runs awesome, what more could you ask for?! -Tony |
Lo-Fi Version | Time is now: 19th May 2024 - 06:07 AM |
