Aaron Cox
Jun 8 2006, 10:05 PM
long story about the down time on my car....
something along the lines of "smaller venturi's and raby jetting suggestion" to optimize performance....
blah blah blah... remove cold start stuff like a few guru's said... "why is it dumping 8 gallons of fuel down each throat" blah blah blah.... call brad... put cold start pistons back in... and finish the carb rebuild....
anyway. so last weekend had the car close.... but my lame dial fuel regulator croaked... and was spitting fuel out the accedl jets at "3" PSI... but falling on its face at 2.5....
Problem solved. KaptKaos sold/traded me a CB rotary internal regulated pump...
car idles great. starts up first crank. roll onto throttle, idle circuits werkin bitchin, and i was getting a little hesitation onto main tranisiton but would do OK at WOT.....
up the main jet to a 135 from a 130 and it is BADASS....
totally smooth thru the powerband, no smoke, no hiccups, backfires or coughing.....
runs AWESOME. i am soooo stoked. car flies. lit up the 8" fuchs wrapped in yokohamas like butta LOL.....
i have a slight crack in a header weld and need to fix it....
gotta throw in the short geared tranny... and go fight some electrical gremlins, and i am good to go...
my dad liked the second gear chirp LOL
AA
TROJANMAN
Jun 8 2006, 10:10 PM
Holy Crap.............Did you see that .........................?......................
wait........
There it is
(good job aaron
jd74914
Jun 8 2006, 10:11 PM
Aaron, do you have a list of your entire engine formula/specs list
BigDBass
Jun 8 2006, 10:13 PM
Aaron Cox
Jun 8 2006, 10:14 PM
blah....
see if i can remember...
71x94 2L
8.5 ish compression
Eurorace header
Big cam....
Mallory CDI box, Unilite Dizzy, and CDI coil on the firewall....
2L heads, with SS valves, big springs, and stock valve sizes....
38mm oil pump, front cooler, mocal thermostat, setrab cooler...
weber 44's, 34 vents, 50 idles, 175 airs, 135 mains....
stock gear box as of now....
have my A F ZDFlip S ZD bpx to go in....
BigDBass
Jun 8 2006, 10:15 PM
There you go with speaking code again....
Hammy
Jun 8 2006, 10:17 PM
QUOTE(BigDBass @ Jun 8 2006, 09:15 PM)
Aaron Cox
Jun 8 2006, 10:21 PM
sorry... gear ratios LOL
jd74914
Jun 8 2006, 10:23 PM
QUOTE(Aaron Cox @ Jun 9 2006, 12:14 AM)
blah....
71x94 2L
8.5 ish compression
Eurorace header
Big cam....
Cool. If my tranny chart here is right that looks like a nice short AX tranny
Aaron Cox
Jun 8 2006, 10:24 PM
QUOTE(jd74914 @ Jun 8 2006, 09:23 PM)
blah....
71x94 2L
8.5 ish compression
Eurorace header
Big cam....
very good son,
with a stock 5th for cruising.... (have to wind out 4th to be in the power band for 5th tho....)
So.Cal.914
Jun 8 2006, 10:49 PM
[quote name='Aaron Cox' date='Jun 8 2006, 09:24 PM' post='699158']
[quote name='jd74914' post='699155' date='Jun 8 2006, 09:23 PM']
[quote name='Aaron Cox' post='699148' date='Jun 9 2006, 12:14 AM']
[/quote]
[/quote]
Have to wind out 4th, bet that will break your heart. Sounds nice...
Aaron Cox
Jun 8 2006, 10:50 PM
3rd at 6k is about 65....
4th at 6k is 90
90 in 5th is about 4200 rpm
im set LOL
Trekkor
Jun 8 2006, 10:58 PM
Great job!!
Now come up here so I can work you over at the a/x KT
Aaron Cox
Jun 8 2006, 10:59 PM
QUOTE(Aaron Cox @ Jun 8 2006, 09:50 PM)
4th at 6k is 90
im set LOL
fine....
A F flipped ZD S and ZD
enjoy
Aaron Cox
Jun 8 2006, 11:00 PM
QUOTE(trekkor @ Jun 8 2006, 09:58 PM)
Great job!!
i never said i could drive!!! HAHHAHAHAH
rick 918-S
Jun 8 2006, 11:02 PM
dinomium
Jun 8 2006, 11:36 PM
Congrats man! Drivin is better than wrenching, at least I think it is!
Rand
Jun 8 2006, 11:42 PM
sherman1
Jun 9 2006, 12:07 AM
Congrats AAron. Great news!
No kidding, very impressive.....we (most of us anyway) are not worthy!
TonyAKAVW
Jun 9 2006, 12:31 AM
Congrats!!!
Thats a big accomplishment... Lots of work into that car. Looks and runs awesome, what more could you ask for?!
-Tony
Andyrew
Jun 9 2006, 12:42 AM
Ya!!!!!
Now.... Were are the pics of your lowly 2.0 smoking the tires?
I could never get mine to do that... then again I had 57rwhp... lol
What is your estimated hp?
Andrew
URY914
Jun 9 2006, 05:58 AM
Good Job!
rhodyguy
Jun 9 2006, 08:18 AM
cb rotarys work very well. i've been beating that horse for some time. now that you've got it running good...i bet you can go down to 45s on the idles. sounds like you're ready to drive to pland.
k
JP Mikey
Jun 9 2006, 08:35 AM
As long as it don't overheat you be cool.....
Gint
Jun 9 2006, 08:36 AM
Grats Aa!
brant
Jun 9 2006, 08:54 AM
good job Aaron!!!!!
Allan
Jun 9 2006, 09:01 AM
Wanna trade?
spunone
Jun 9 2006, 09:02 AM
Did you get time to put on the new stacks??or are ya still dicking with them LOL
Lou W
Jun 9 2006, 09:17 AM
Aaron Cox
Jun 9 2006, 09:54 AM
QUOTE(rhodyguy @ Jun 9 2006, 07:18 AM)
k
hey kev, i owe you for a couple tips you gave me (just not the chokes tip LOL) nut for the tomlinson book, and the rotary pump shizzle....
works great... 50 idles are just right...
AA
Aaron Cox
Jun 9 2006, 09:55 AM
QUOTE(spunone @ Jun 9 2006, 08:02 AM)
Havent cut the plates out yet...... and need to lower motor 1/4" inch to clear on the right side... but that may bring headaches...
so yes.. still dicking LOL
AA
rhodyguy
Jun 9 2006, 10:09 AM
hey, is there a trick to get the rotor out of the mallory? it's either a snug fit or the little screw retains it, and i don't want to reef on it. i think my power loss may be due to a toasted rotor and cap. it's as it came to me from daveh and i have no idea how many miles he put on it prior to.
k
Aaron Cox
Jun 9 2006, 10:11 AM
yeah.. they are on there snug....
grab and pull, maybe twist just a tad.....
BTW - caps are like 25 bucks (i broke one
Gint
Jun 9 2006, 10:12 AM
QUOTE(rhodyguy @ Jun 9 2006, 10:09 AM)
k
I wondered the same thing on mine. But I finally bit the bullet and gave it a good yank. It's a pretty tight fit (at first anyway).
Aaron Cox
QUOTE(Gint @ Jun 9 2006, 09:12 AM)
k
what car do you have a unilite in??
Gint
Jun 9 2006, 10:15 AM
QUOTE(Aaron Cox @ Jun 9 2006, 10:12 AM)
It'll go in the zambeziteen... but I haven't installed it yet. At the moment it's still lookin pretty on my desk at home.
rhodyguy
Jun 9 2006, 10:18 AM
yep. cap and rotor run the better part of $40(damn). they seem to last tho. hopefully that's my problem.
k
Toast
Jun 9 2006, 01:29 PM
So, where's my ride?
drewvw
Jun 9 2006, 02:02 PM
sounds schweeeeeeeeeet
bd1308
Jun 9 2006, 04:25 PM
Great
your's gets running, mine goes down
b
yeahmag
Jun 10 2006, 09:30 AM
Aaron,
Where did you mount your CB Rotary pump? I have one waiting to go in...
Thanks.
-Aaron
Aaron Cox
Jun 10 2006, 09:39 AM
QUOTE(yeahmag @ Jun 10 2006, 08:30 AM)
Aaron,
Thanks.
-Aaron
front trunk
yeahmag
Jun 10 2006, 09:41 AM
Any tips on wiring it up or mouning it? Do you happen to have any pics?
Thanks!
-Aaron
Aaron Cox
Jun 10 2006, 09:44 AM
i had a facet on rubber isolators up front.... so this went in the same spot...
i can take some pics...
or you can come over and help me diagnose a small lean stumble on transition:)
yeahmag
Jun 10 2006, 09:53 AM
I'd be happy to do that! I'm most comfortable with Dell's, but I should be able to help. Are you anywhere near John's machine shop? I'll probably be there next weekend...
You are always welcome up here, I have a full compliment of carb toys and seeing as I'm a Dad now it can be hard to steal away some time...
Let me know either way.
-Aaron
Aaron Cox
Jun 10 2006, 09:54 AM
ive got the web's 95% there.... everything i read says it is venturi selection... but the sweet spot on this motor BEGINS at 3500... so i may just have to deal with it...
we also think that we might be able to "trick" this transition with more accell pump squirt...
AA
yeahmag
Jun 10 2006, 09:57 AM
What vents, E-tubes, mains, and idles do you have in them? What size are the bodies?
-Aaron
Aaron Cox
Jun 10 2006, 09:59 AM
weber 44's f11, 135 mains, 50 idles 175 air....
yeahmag
Jun 10 2006, 10:01 AM
What size venturi?
