i got the herky jerky, but only at approx 2500-3500 prm |
sk8kat1 |
Jun 8 2006, 10:30 PM
Senior Member Group: Members Posts: 911 Joined: 10-October 05 From: belvidere ,IL Member No.: 4,937 |
ok it was running good .. then I posted cause my tach crapped out.....
turns out teh wire to the coil broke -- I stripped the wire attached a new connector and it was good... I also added alittle oil because it seemed like if I drove iyt a bit hard the oil light came on ... I also replace the front turn signal bulbs ..... now I go the herky jerkies at approx 2500 -3500 rpm (IMG:style_emoticons/default/WTF.gif) HELLPPPP!!!! (IMG:style_emoticons/default/sad.gif) |
So.Cal.914 |
Jun 8 2006, 11:08 PM
I don't speak mid western, can you explain "herky jerky" for me. And elaborate
please. |
jhadler |
Jun 8 2006, 11:12 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
Look at the Throttle Position Switch. They tend to wear the most right around that rpm range (where freeway cruising is most commonly at). The switch is a set of wiper contacts running over a printed circuit. The cicuit traces can get dirty from build up, and create a hesitation or bucking effect.
-Josh2 |
sk8kat1 |
Jun 8 2006, 11:45 PM
Rand |
Jun 8 2006, 11:48 PM
Look at the Throttle Position Switch. They tend to wear the most right around that rpm range (where freeway cruising is most commonly at). The switch is a set of wiper contacts running over a printed circuit. The cicuit traces can get dirty from build up, and create a hesitation or bucking effect. -Josh2 Yeah, when I saw "herky jerkies at approx 2500 -3500 rpm," TPS was my first thought. All the wire connections good? |
sk8kat1 |
Look at the Throttle Position Switch. They tend to wear the most right around that rpm range (where freeway cruising is most commonly at). The switch is a set of wiper contacts running over a printed circuit. The cicuit traces can get dirty from build up, and create a hesitation or bucking effect. -Josh2 i HAVE NOT BEEN DRIVING AT ALL .. IT WAS ON JACKSTANDS FOR THE LAST 5 MONTHS .. i TOOK OFF THE STANDS IT RAN GREAT ... THEN THE SERIES OF EVENTS ... THE po REPLACED THE tps BEFORE i GOT IT ... COULD ANY OF THE THINGS THAT i DID CAUSE THIS? .. IS THERE ANOTHER CONNECTION ON THE COIL THAT I MIGHT HAVE BUMPED THAT WOULD CAUSE THIS SYMPTOM? |
sk8kat1 |
Jun 9 2006, 12:20 AM
ok i disconnected the wires to the TPS and re conected a few times to try and create a cleaner and better conection .. It seems to run better now but still has a bit of a chug to it .. I did get a spare TPS when I bough the car if I swap them out is there any thing I should be aware of or watch out for? (IMG:style_emoticons/default/smash.gif)
sk8kat1 |
Jun 9 2006, 08:09 AM
is it possible that it just needs to be calibrated?
jhadler |
Jun 9 2006, 11:00 AM
Can you take off the TPS and open it up? The contacts on the circuit board can get dirty and cause hesitation. A soft pencil eraser is just right for cleaing the circuit contacts, and a piece of fine emory paper for cleaning the wiper contacts.
-Josh2 |
TROJANMAN |
Jun 9 2006, 11:04 AM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
if you have a mullet, shave it, and they will go away (IMG:style_emoticons/default/chairfall.gif) it worked for his achy-braky Attached image(s) |
sk8kat1 |
Jun 9 2006, 11:49 AM
if you have a mullet, shave it, and they will go away (IMG:style_emoticons/default/chairfall.gif) it worked for his achy-braky (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/poke.gif) |
jgara962 |
Jun 10 2006, 09:29 AM
Yo, this is how I roll Group: Members Posts: 823 Joined: 5-April 05 From: Napa, CA Member No.: 3,879 Region Association: Northern California |
I'm having the same issue between 3,000 - 3,200 RPM. Where is the TPS?
sk8kat1 |
Jun 10 2006, 06:38 PM
Lo-Fi Version | Time is now: 25th May 2024 - 03:37 PM |
