ok it was running good .. then I posted cause my tach crapped out.....
turns out teh wire to the coil broke -- I stripped the wire attached a new connector and it was good... I also added alittle oil because it seemed like if I drove iyt a bit hard the oil light came on ... I also replace the front turn signal bulbs .....
now I go the herky jerkies at approx 2500 -3500 rpm
HELLPPPP!!!!
