Modified flywheel, messing around on a cnc at work |
muddboy |
Jun 8 2006, 11:35 PM
Member Group: Members Posts: 91 Joined: 10-November 04 From: Anahiem, CA Member No.: 3,085 Region Association: Southern California |
was just mesing with one of the cnc machines at work today and came up with this:(IMG:http://www.t-mobilepictures.com/photos/photo04/1e/85/4aa050a1a584.jpg)
(IMG:http://www.t-mobilepictures.com/photos/photo09/5f/41/1e33ff901be0.jpg) any suggestions? I'm planing on tweeking it more. Its 13lbs now |
Aaron Cox |
Jun 8 2006, 11:36 PM
if you need a test dummy to run it....
im all yours (IMG:style_emoticons/default/smile.gif) looks super cool, functional and fun at the same time! |
Type 4 Unleashed |
Jun 9 2006, 12:00 AM
CREATIVE TYPE lV ENGINEERING Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None |
Here are some ideas:
(IMG:http://i71.photobucket.com/albums/i134/Type4Unleashed/5.jpg) (IMG:http://i71.photobucket.com/albums/i134/Type4Unleashed/2.jpg) (IMG:http://i71.photobucket.com/albums/i134/Type4Unleashed/Schwungrad36kggebohrt_3.jpg) <a href="http://photobucket.com" target="_blank"><img src="http://i71.photobucket.com/albums/i134/Type4Unleashed/Schwungrad32kggebohrt.jpg" border="0" alt="Photobucket - Video and Image Hosting"></a> (IMG:http://i71.photobucket.com/albums/i134/Type4Unleashed/3.jpg) |
muddboy |
Jun 9 2006, 11:50 PM
That looks like alot more than what I'm looking to do... but the pattern on the cutts looks intresting... I have 2 more used flywheels to test this out on. I will have to try writing a new program to do something like that
and Aaron something could be worked out???? |
So.Cal.914 |
Jun 9 2006, 11:56 PM
i didn't think they could get any lighter than what I am running, I WAS WRONG.
Looks Good. |
LowGT |
Jun 10 2006, 12:02 AM
1.8 and Proud! Group: Members Posts: 583 Joined: 2-October 05 From: Wylie, TX Member No.: 4,904 Region Association: Southwest Region |
I'm curious, what do those 2 styles weigh?
Mueller |
Jun 10 2006, 12:09 AM
nice.....Automotion used to sell flywheels cut in a similar fashion...I asked Rich @ High Performance House about them and he mentioned that the torque requirred to turn over a Type IV had a tendancy of breaking those modified flywheels...of course it could have been due to improper machining or not leaving a nice small radii.......let ArRoN run one and do some testing (IMG:style_emoticons/default/burnout.gif)
McMark |
Jun 10 2006, 02:04 AM
Breaking them where? I'm curious.
Mueller |
Jun 10 2006, 01:48 PM
Aaron Cox |
Jun 10 2006, 01:50 PM
hey! i gotta swap to my short geared tranny soon... so i would be in a position to try one (IMG:style_emoticons/default/smile.gif)
scottb |
Jun 10 2006, 01:55 PM
who wants a PEZ?! Group: Members Posts: 1,993 Joined: 27-December 02 From: south-(not north)-wick, MA Member No.: 32 Region Association: North East States |
i am gonna be putting in a new motor/tranny soon if'n you need someone to run one.... i will even send you my old flywheel as i have a newly machined backup....
cheers!!! |
Cap'n Krusty |
Jun 10 2006, 01:56 PM
Interesting. However, removing weight from points near the center may make it lighter in terms of total weight, but weight removed there has little effect on the way it'll rev, and it weakens it considerably. That said, I've seen an old T4 Super Vee flywheel that looked suspiciously like chicken wire .................. Even the clutch mating surface was heavily drilled. The Cap'n
Aaron Cox |
Jun 10 2006, 01:59 PM
weight further from axis of rotation makes biggest difference as krusty is saying
TimT |
Jun 10 2006, 02:14 PM
906 flywheel & my 911 flywheel fwiw
anthony |
Jun 10 2006, 02:38 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
smdubovsky |
Jun 10 2006, 02:43 PM
Member Group: Members Posts: 331 Joined: 27-September 04 From: Silver Spring, MD Member No.: 2,837 Region Association: MidAtlantic Region |
Mark Henry |
Jun 10 2006, 03:13 PM
The Crusty one is right about weight removed from near centre...useless. Also never cut the backside of the friction surface.
You will need to beef up your valve train or you will float your valves like crazy. I don't recommend doing this on a daily driver, no inertia, you will be on/off the gas all the time. With a light flywheel, if you do put it on a DD, you'll need the power to back it up. |
muddboy |
Jun 10 2006, 03:34 PM
The shop I am at can do the ballancing (and I'm planing on it for the test ones), and we are getting the wheel to grind the surface.
The Crusty one is right about weight removed from near centre...useless. Also never cut the backside of the friction surface. You will need to beef up your valve train or you will float your valves like crazy. I don't recommend doing this on a daily driver, no inertia, you will be on/off the gas all the time. With a light flywheel, if you do put it on a DD, you'll need the power to back it up. I am trying to get a couple of profiles to cut to... I want to have 2 versions, a light and lighter. That first one is at 13lbs, and I dont want to be much lighter for this one... then I'll try to do one around 10 or so lbs. |
gregrobbins |
Jun 10 2006, 04:12 PM
Member: Team NARP Group: Members Posts: 1,515 Joined: 23-March 04 From: Arizona Member No.: 1,844 Region Association: Southwest Region |
I don't remeber where, but I read about someone testing different flywheel weights. They had one down to 9 lbs but it was a track only application as it reved too wierd for street use. They had one at 11 lbs that worked better on the street, but it too was tempermental. I recall they figured 14 lbs was a good all around solution.
Mueller |
Jun 10 2006, 04:16 PM
is it only me that finds freshly machined parts sexy??? (IMG:style_emoticons/default/drooley.gif)
Lo-Fi Version | Time is now: 16th May 2024 - 09:22 PM |
