Front Brake Spreader Spring, I think thats what it's called... |
yeahmag |
Jun 11 2006, 11:43 AM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I'm replacing my front and rear brakes with used Pagid Orange pads. One of my fronts spreaders broke at the rivit and I need to source another. I'd like to replace all 4 with new ones... Any idea where I can get these?
-Aaron |
Aaron Cox |
Jun 11 2006, 11:52 AM
pelican is close.... they should have it....
in a pinch, you can rivit it back together..... got any 32 venturis for a weber 44? |
BigDBass |
Jun 11 2006, 11:55 AM
Dumb Question Champion Group: Members Posts: 1,438 Joined: 11-January 06 From: Chicago (south 'burbs) Member No.: 5,405 Region Association: Upper MidWest |
Mine broke upon removal as well. As per suggestions here, I just used pop rivets to rivet them back together after drilling out the old one. I used 1/8x1/8 rivets and a $20 Craftsman pop rivet gun. You might want to drill out and replace the others as well so you know they're good.
yeahmag |
Jun 11 2006, 11:56 AM
LOL... I've got calls out to my weber buddies (VW drag race friends). Hopefully I'll here something soon.
I'll give Pelican a ring. Thanks for the advice. -Aaron |
JPB |
Jun 11 2006, 12:01 PM
Do you mean antirattle clips?
yeahmag |
Jun 11 2006, 12:22 PM
No... It's the weird spring/wedge combo that sits on top of the pads (held in by the pins). The way I understand it the idea is to slightly push the pads out and away from the rotor. But what do I know... (IMG:style_emoticons/default/smile.gif)
-Aaron |
Aaron Cox |
Jun 11 2006, 12:25 PM
aaron.... been a while since i saw /4 front calipers...
i have a bunch of new pin retaininer clips if you need em... kinda like a cotter pin for the pins... so they dont fall out... |
yeahmag |
Jun 11 2006, 02:49 PM
Those are for the rears if I read the parts diagrams correctly... Is that right?
-Aaron |
Aaron Cox |
Jun 11 2006, 06:15 PM
probably. like i said.. its been a LOOONG time since i touched a 4 pooper front caliper...
Lo-Fi Version | Time is now: 27th May 2024 - 06:23 AM |
