96x71 or 96x78 motor - That's the question |
KenH |
Jun 13 2006, 12:23 AM
Senior Member Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 |
In playing with my el-cheapo dyno program it looks like you can get the same HP with either a 71mm or 78mm stroke. The 78mm however gives a bit more torque.
Over all the CAM seems to give the biggest improvement. The question is - is it worth the hassle to go to 78mm stroke (T1 rods, special pistons, clearence issues, cost of rods, crank, pistons) for 10'lb of torque?? Looks like 96mm x 71mm with good heads, proper CAM, optimun fuel delivery, FI or Carb, will make a pretty good motor. Comments?? Ken |
Lo-Fi Version | Time is now: 18th May 2024 - 10:31 PM |
