Northeast wrenching, Let's make this a habit..... |
dtravni |
Jun 18 2006, 10:51 AM
Newbie Group: Members Posts: 14 Joined: 24-October 05 From: Lincoln, NE Member No.: 4,993 |
And here's a pic of the new puppy.... His name is "The Captain". "Northeast wrenching, Let's make this a habit..... Dear "Northeast wenchers" - did you mean "habit" -or- ... (ahem) ... ADDICTION ??? Seriously, it looks like youse guys got somethin' super goin' = DO-DO-DO keep it up - but for 1500 mi (i'm stuck out here in the interior) i'd have been there & lovin' it. just a suggestion, RMITAL` - "Tyke" has to feed his putt-putt (known as "Piglet") a steady diet of octane booster - looks to me like an investment in Pepto Bismal might be in order to keep this unfortunate green thingie happy ... : ) dtravni (IMG:style_emoticons/default/givemebeer.gif) |
JPB |
Jun 18 2006, 11:17 AM
i love porsche |
Jun 18 2006, 09:59 PM
Senior Member Group: Members Posts: 1,547 Joined: 6-May 04 From: Nutley, NJ Member No.: 2,030 Region Association: North East States |
this was tons of fun being there on saturday, even though progress on my car has been practically non existent, i just loved being able to do SOMETHING...no matter whos car it was...we definetly need to make a habit out of this...
type11969 |
Jun 19 2006, 10:52 AM
Senior Member Group: Members Posts: 1,231 Joined: 2-December 03 From: Collingswood, NJ Member No.: 1,410 Region Association: North East States |
I'll definitely try to make it next time. What about before/after this:
http://www.914world.com/bbs2/index.php?showtopic=53265&st=20 Anyone actually know if the above was made "official"? -Chris |
Leo Imperial |
Jun 19 2006, 11:47 AM
Do you have to use so many cuss words? Group: Members Posts: 906 Joined: 29-November 04 From: 914 Roadshow - Glen Cove NY Member No.: 3,192 Region Association: None |
Great to see you guys.
Sorry I couldn't stay long. Not bad for the first round, but not enough (IMG:style_emoticons/default/beer3.gif) We can fix that. It was nice to see all that rust in one place (IMG:style_emoticons/default/smile.gif) |
ptravnic |
Jun 19 2006, 01:19 PM
Senior Member Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None |
Leo - Can you post a couple of the pics you took?
Also, the "new" fuel pump we swapped turned out to be pumping 70psi!!! Turns out it was a 911 pump - we musta swapped the things 3 or 4 times before checking the pressure and then realizing the old one was not getting a good ground. We were a bunch of monkey's scratching our heads... but then we rigged a lil copper wire between the bracket and the pump itself to ensure a good ground and got the car back on the road... |
i love porsche |
Jun 19 2006, 01:20 PM
yes chris, im still up for the july first get together at the whiskey cafe...how about a sign in here
Leo Imperial |
Jun 19 2006, 01:30 PM
Leo - Can you post a couple of the pics you took? Also, the "new" fuel pump we swapped turned out to be pumping 70psi!!! Turns out it was a 911 pump - we musta swapped the things 3 or 4 times before checking the pressure and then realizing the old one was not getting a good ground. We were a bunch of monkey's scratching our heads... but then we rigged a lil copper wire between the bracket and the pump itself to ensure a good ground and got the car back on the road... I'll try to post them tonight from home. I knew that pump didn't look right. It was way bigger than the original. Did the car run better when it left or when it came in? |
ptravnic |
Jun 19 2006, 01:38 PM
I knew that pump didn't look right. It was way bigger than the original. Did the car run better when it left or when it came in? Rich was having a bit of trouble getting power in the first few minutes of our drive toward the freeway but it cleared up and he seemed A-OK up to where we split off (I had to run to Home Depot - a man's job is never done). He's still having some idle/tuning issues. Thats not much of a surprise though being that it was "tuned" w/o having the valves adjusted. He prob just needs to start from the beginning & get a dwell on there to adjust the timing, then go through the FI pieces one by one to test each is working correctly. I tried to get the idle to behave by adjusting the air screw and moving the knob on the ECU but those are just band aid fixes to keep him from stalling out and should get him moving for the time being. Bring on Paul Brad Anders' D-Jet writeup!! -pt |
type11969 |
Jun 19 2006, 01:43 PM
Hopefully it is more than just you and me Aaron considering neither of us have a working 914!
What do you think about doing some wrenching before or after the Whiskey Cafe (both?) at this garage? Or are they far apart? -Chris |
jet1 |
Jun 21 2006, 07:00 PM
Member Group: Members Posts: 311 Joined: 16-June 04 From: Accord,NY Member No.: 2,213 Region Association: North East States |
Nice to see some northeast people get together! If you guys keep it up I may just have to take a drive down. |
jet1 |
Jun 24 2006, 01:34 PM
Last but not least...my wounded 914 watched on the side lines. We're all thinking winter "group" project, getting it back on the road. Ray, keep us posted on the next wrenching get together. If I can make it down I will bring a fender I cut off a parts car. I also have a rear section that is in poor condition, but you may be able to use part of it for the trunk repair. Keith Attached image(s) |
Leo Imperial |
Jun 25 2006, 06:34 AM
Better late than never.
Here are some pics from the first monthly wrench. Got a nice group picture Attached image(s) |
rmital |
Jun 25 2006, 08:13 AM
Northeast optimist Group: Members Posts: 1,947 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
Last but not least...my wounded 914 watched on the side lines. We're all thinking winter "group" project, getting it back on the road. Ray, keep us posted on the next wrenching get together. If I can make it down I will bring a fender I cut off a parts car. I also have a rear section that is in poor condition, but you may be able to use part of it for the trunk repair. Keith Excellent Keith...the fender would be great! I hoping for July 1st. (IMG:style_emoticons/default/welder.gif) |
jet1 |
Jun 25 2006, 10:24 AM
I can't make it down for the 1st. I wanted to come wrench and go to the whiskey cafe, but I allready made plans to go to Cape Cod for the weekend. The next time after the 1st I will drive down for sure. So keep up the wrenching and I will see you guys one of these days.
BTW I will check and see if I have any of the front headlight parts that you will need also. Keith |
rmital |
Jun 30 2006, 11:02 AM
getting together tomorrow, Saturday July 1...about noon.
nycchef fuel pump relocation. reply to this thread if you could make it or have any questions about location. I check in later on this afternoon...... |
turboman808 |
Jun 30 2006, 11:48 AM
Advanced Member Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States |
getting together tomorrow, Saturday July 1...about noon. nycchef fuel pump relocation. reply to this thread if you could make it or have any questions about location. I check in later on this afternoon...... Yeah I just need directions and even better a google map link! |
Dr Evil |
Jun 30 2006, 12:02 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I am gonna try to make it to one of these towards the end of July if you have on then.
ptravnic |
Jul 12 2006, 12:51 PM
Any chance for this w'end?
Ray - any chance of getting some garage time this w'end? |
rmital |
Jul 12 2006, 12:58 PM
...I'm finding out now...or waiting to hear back Movie Time's schedule. Soprano's started shooting again, so they're actually pretty busy over there....welding rigging on cars....
..which probably wouldn't be bad, we'd just have to let them have priority over space and lift...since it's their place... I would probably shoot for Sunday morning. |
Lo-Fi Version | Time is now: 4th June 2024 - 08:26 PM |
