2 Pages V < 1 2
> My Engine progress as of today, ...if anbody cares
ChrisReale
post Oct 3 2003, 02:07 AM
Post #21
Sleazy
What did you have to do to use the 911 adjusters?
Bleyseng
post Oct 3 2003, 07:52 AM
Post #22
Aircooled Baby!
You need a set of early 8mm rocker arms. Mill off about .60 of the face of the rocker so the swivel has room to move around and so the rockers will fit back in. Check the geometry after you install and shim to adjust or cut the pushrods.
I set the valve clearance at .005 as there is alittle slop in the swivel foot. If I set it to .008 the valves are just too damn noisey!
Why Chris? You want a set of early rockers? I have one set left.
Geoff
swood
post Oct 3 2003, 08:34 AM
Post #23
I had my stock '75 rockers, then they got tossed when the heads were done. Now I don't know what I've got other than they are for an 8mm adjuster. How can you tell early/late?
Good Idea about milling them. It seems like I'm 3/8" too far out. The rocker assy doesnt even rest on the head. And the adjusters have no free play.
Jake Raby
post Oct 3 2003, 08:48 AM
Post #24
Engine Surgeon
Looks like you need another try at the valve train geometry. Are you TRYING to use a stock pushrod??? The web 73 is a mild cam, but one of the harder ones to gain full lift from and maintain proper half lift parameters to keep the valvetrain alive.
You will need to deck the face of your rockers .060, grab an adjustable pushrod and start doing the process. I did a build up with VW Trends last year and showed this in an entire article one month, step by step on a TIV engine. Should be informative for you.
Bleyseng
post Oct 3 2003, 09:34 AM
Post #25
Aircooled Baby!
Early rockers are 8mm
Late rockers are 10mm
If you are using the 911 swivel feet (only use the real Porsche ones) then you have to mill the rockers to make room for the ball feet.
thesey914
post Oct 3 2003, 09:52 AM
Post #26
Yeah looking at your studs for the rocker assembly the 7mm nuts are only just hanging on.....I think I ground off 1/8 " to make them fit plus a .40mm spacer to make mine fit.
Bleyseng wrote -I set the valve clearance at .005 as there is a little slop in the swivel foot. If I set it to .008 the valves are just too damn noisy!
Good plan -I'll try that as I expected mine to be a lot quieter
porsche735
post Oct 3 2003, 09:54 AM
Post #27
Also, not sure if it is just from a mock up, but your studs are not sticking out far enough. You need to have some thread past the nuts holding your rocker arm assemblies.
Chris
porsche735
post Oct 3 2003, 09:56 AM
Post #28
Looks like J. Seymore and my messages crossed in the Ether. Same point....
Chris
Tom Perso
Post #29
Crazy from the Cold...
As a BTDT view, take my advice.
Dump the 7mm rocker studs, call up FAT and get a set of 8mm ones. They are longer and use 8x1.25 thread, so you can get a set of T1 head nuts and cinch them down.
Do it before you fire it up.
Later,
Tom
swood
post Oct 3 2003, 12:10 PM
Post #30
Hey guys, just mocking it up to see where I'm at. I don't mind the criticism, btw. Yeah I've got stock pushrods. Didn't know what the big deal was with using them. What should I use?
I think that removing material from the rocker arm will help plus a bit of a shim.
I see that use of an adjustable rod will help figure out what the final rod length needs to be.
Is replacing the 7mm rocker stud w/8mm that big of a deal?
Thanks for the valuable second, third and 12th opinions. It's just what I need right now.
The 911 adjusters are from Porsche.
Steve
swood
post Oct 3 2003, 12:31 PM
Post #31
QUOTE(Jake Raby @ Oct 3 2003, 06:48 AM)
Anyone have a copy of this they could lend/post?
MarkV
post Oct 3 2003, 12:57 PM
Post #32
Fear the Jack Stands
This article might help ? http://www.vwtrendsweb.com/tech/0207vwt_be...ater/index.html
swood
post Oct 3 2003, 03:55 PM
Post #33
QUOTE(swood @ Oct 2 2003, 09:11 PM)
Yeah, I asked and Stromberg sent me the part # and price... 6 bucks. Let me know what you come up with. I may be interested.
PP Part#021-101-267 $ 5.50
swood
post Oct 6 2003, 04:36 PM
Post #34
I drove the Eggplant as hard as I could over the weekend (just in our neighborhood since it's got no current tags, or functioning brakes).
There is also no seal between the edge of the engine shelf and tin. In some areas no shelf either. No wonder it got so hot, it can't cool right. And it was about 150 degrees in the cockpit, no wonder. With no proper cooling, it shouldn't be driven. So, I'll just park it for a while. I took a bunch of pictures this weekend, so I'll try and post them later.
Jeff Bonanno
post Oct 7 2003, 02:40 AM
Post #35
il dottore
no cooling - it shouldn't be driven? how 'bout no brakes - it shouldn't be driven?!
(ask me how i know...)
a vehicle does not need to look good, start, idle, rev, run, . it only needs to stop.
(wait, don't ask)
jbb (IMG:style_emoticons/default/ph34r.gif)
swood
post Oct 7 2003, 07:33 AM
Post #36
QUOTE(Jeff Bonanno @ Oct 7 2003, 12:40 AM)
(IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif)
Good one. Haven't you ever had one of those moods, where little details like non functioning brakes doesnt stop you from hitting the street? Maybe it was in part due to the BBS being down. Someone once said, Log off and drive. So i did. (IMG:style_emoticons/default/mueba.gif)
Jeff Bonanno
post Oct 8 2003, 01:57 PM
Post #37
il dottore
yah - once. it landed me in jail! (IMG:style_emoticons/default/w00t.gif)
2 Pages V < 1 2
- Lo-Fi Version Time is now: 16th June 2024 - 08:48 PM
