Question about the throwout bearing |
brer |
Jun 20 2006, 11:27 PM
Advanced Member Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
replaced the bearing and the plastic cup in the arm today.
The way that arm is designed is pretty cool. But i'm wondering what the standard lubrication is for the inner surface on the bearing and the plastic cup? Is that cup a dry fitting? |
Brad Roberts |
Jun 20 2006, 11:59 PM
I have used a high temp wheel bearing grease for years... but... I believe they are designed to be installed dry.
The grease traps dirt and promotes premature wear. B |
bob91403 |
Jun 21 2006, 12:02 AM
Senior Member Group: Members Posts: 618 Joined: 15-September 04 From: Los Angeles, CA Member No.: 2,763 |
replaced the bearing and the plastic cup in the arm today. The way that arm is designed is pretty cool. But i'm wondering what the standard lubrication is for the inner surface on the bearing and the plastic cup? Is that cup a dry fitting? A little bit of moly grease is all you need. Cup? Should be two plastic retainers. The thowout bearing itself is sealed and prelubed. A little bit of moly on the tube, and the pivot points of the fork is all you need. |
Bleyseng |
Jun 21 2006, 08:05 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
A dap of molygrease in the plastic cup and on the pilot shaft tube for smooth operation. Note a dap not freakin ton of grease as it will just load up with clutch dust and stick! (IMG:style_emoticons/default/rolleyes.gif)
brer |
Jun 21 2006, 09:40 AM
The bearing has what looks like a grease groove on the inside surface.
so I used a little in there. Was hesitant to put anything anywhere as i figured that the clutch dust would just stick to it and mess it all up. |
davep |
Jun 21 2006, 10:14 AM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Cup? Should be two plastic retainers. If'n you don't know about the cup, you better learn fast. The pivot ball sits in the cup and the cup has a hard life. It wears out quicky, and should be replaced with every clutch change. A tiny amount of grease on the ball is enough. I don't lube anything else. Grease anywhere else tends to attract dirt and causes more wear than a lack of lubrication. I think the groove mentioned acts more like a guide to wear on the bearing, and reduces the friction of the bearing on the tube by reducing surface area. Make sure the plastic bushings on the bearing are in good shape also. If they are worn the bearing is too loose and you will get more rapid wear. |
Bleyseng |
Jun 21 2006, 10:18 AM
Brer, I'll see your green frog and raise you one blue frog.
Jun 21 2006, 10:39 AM
If'n you don't know about the cup, you better learn fast. The pivot ball sits in the cup and the cup has a hard life. It wears out quicky, and should be replaced with every clutch change. When I had my engine out last, the cup looked good--and it did not want to come out, so I left it alone. I just recently replaced the clutch on the car. The cup looked fine, still, and it really did not want to come out! I had to break it into a bunch of pieces with a hammer and chisel to get it out. I actually scored the bore where the bushing lives in two spots by doing this... Maybe I'm just lucky? Unlucky? --DD |
Bleyseng |
Jun 21 2006, 10:43 AM
No, you just like doing things the hard way! (IMG:style_emoticons/default/alfred.gif)
brer |
Jun 21 2006, 11:03 AM
I replaced all the plastic clips and cups so i'm set.
as far as getting the cup out I stuck in a chisel i had, gave it half a turn and pry'd it out. easy. now i'm looking for a good quality clutch disk. there are some polish Sachs on ebay... but i'm not sure about those. |
brer |
Jun 21 2006, 11:04 AM
bob91403 |
Jun 21 2006, 12:11 PM
Mike D. |
Jun 21 2006, 06:53 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
Don't forget to instal a dime under the plastic cup to shorten the throw. (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 25th May 2024 - 06:17 PM |
