What am I missing here?, door trim issue............. |
East coaster |
Jun 21 2006, 10:28 PM
Senior Member Group: Members Posts: 1,673 Joined: 28-March 03 From: Brigantine, NJ Member No.: 487 Region Association: None |
I assmebled my doors and there's a big gap between the window trim and the little end cap. The cap does not appear to be damaged/broken or missing anything and both driver and passenger sides are the same.
Is there something else missing here? This gap can't be right. It's a '74 body for reference. |
Jun 21 2006, 10:42 PM
Resident German Group: Admin Posts: 41,644 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
the endcap is correct for a '74. it appears the seal was cut for an early door.
when i got my new seals they were too long and i had to cut them myself to fit. are those seal brand new? you *can* stretch the seals quite a bit, but that looks like a pretty big gap you got there. how does it fit in the front? (IMG:style_emoticons/default/idea.gif) Andy |
BigDBass |
Jun 21 2006, 10:57 PM
Dumb Question Champion Group: Members Posts: 1,438 Joined: 11-January 06 From: Chicago (south 'burbs) Member No.: 5,405 Region Association: Upper MidWest |
My seals look like that too. 1/2 an inch or so on either side on both doors. |
Midtowner |
Jun 21 2006, 11:00 PM
Ooooo! Group: Members Posts: 652 Joined: 21-December 04 From: Sunnyvale, CA Member No.: 3,316 Region Association: None |
The rubber shrinks. Mine did after the car was sitting in the garage for 16 years. I installed new ones but you may have to cut one of the ends to fit properly. Also, be careful not to chip or crack the end cap. I believe they are NLA or very expensive. My $0.02. (IMG:style_emoticons/default/smile.gif)
Jun 21 2006, 11:01 PM
(IMG:style_emoticons/default/popcorn[1].gif) My seals look like that too. 1/2 an inch or so on either side on both doors. as i said, you can stretch them quite a bit. center them so you have an equal gap front/end and then work them from the center to the sides using your thumb ... they'll stretch ... but my point was, my new seals were too long for my early doors and i had to cut them down. they would have been a almost perfect fit for a late door ... i got mine from HPH ... (IMG:style_emoticons/default/smile.gif) Andy |
rhodyguy |
Jun 22 2006, 09:09 AM
door window seals (squeegees) are cheap. the bird gets $9.25 each. there are both left and rights. 70-76. use glycerin to help slide them in. the problem with stretching them is, the squeegees will want to return to their original form. if you trim to fit immediately the gap(s) might grow. run them forward so they sort of jam into the front glass guide and trim the rear a little long. you can adjust and shorten them at a later date. it's pretty hard to add material back on. get new inner fuzzy strips when you're ordering if the old ones are shot.
k |
Root_Werks |
Jun 22 2006, 09:15 AM
Village Idiot Group: Members Posts: 8,321 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
door window seals (squeegees) are cheap. the bird gets $9.25 each. there are both left and rights. 70-76. use glycerin to help slide them in. the problem with stretching them is, the squeegees will want to return to their original form. if you trim to fit immediately the gap(s) might grow. run them forward so they sort of jam into the front glass guide and trim the rear a little long. you can adjust and shorten them at a later date. it's pretty hard to add material back on. get new inner fuzzy strips when you're ordering if the old ones are shot. k (IMG:style_emoticons/default/agree.gif) squeegies are cheap and the ones I have bought have all been too long. I usually squsih them and trim off as little as possible. Seems like most rubber shrinks over time anyway. |
szuccaro |
Jun 22 2006, 09:43 AM
ZUKE Group: Members Posts: 200 Joined: 27-June 03 From: Cameron Park, CA Member No.: 862 Region Association: Northern California |
Had the same issue when I replaced mine... like Sir Andy says, they stretch quite a bit. Try it, you'll be surprised how much the gap will shrink once they are stretched. Steve
Lo-Fi Version | Time is now: 18th May 2024 - 05:27 PM |
