> Weltmeister vs. Ground Control rear coilover conversion kit?, anybody have experience with these?
monkei
post Jun 22 2006, 09:58 PM
slave to rust....
Weltmeister
http://www.automotion.com/productpage.aspx...il+Over+Kit+914
Ground Control Coil-Over Conversion Kit (little down the page)
http://www.livermoreperformance.com/porsche_suspension.html
anybody compared the kits. raced with either? can anybody suggest spring rates? the weltmeister kit starts at 150lb and goes on up to 300. before coilovers i was thinking about the 150-180lb range. dont know what the rates are for the ground control kit.
Aaron Cox
post Jun 22 2006, 09:59 PM
Professional Tinkerer
colemanracing.com
35 bucks a side plus springs i belive....
look at my blog. lots of pics.
monkei
post Jun 22 2006, 10:04 PM
slave to rust....
QUOTE(Aaron Cox @ Jun 22 2006, 08:59 PM) *
colemanracing.com
did you diy out of universal components or was this stuff part of a 914 specific kit? i couldn't find it.
post Jun 22 2006, 10:06 PM
Resident German
i got my setup from rich at HPH. forgot what i paid for it, call him and ask ...
(IMG:style_emoticons/default/smile.gif) Andy
monkei
post Jun 22 2006, 10:15 PM
slave to rust....
QUOTE(SirAndy @ Jun 22 2006, 09:06 PM) *
remember manufacturer(s) name? i see eibach springs, who makes the rest?
who makes ein superior produkt?
Aaron Cox
post Jun 22 2006, 10:17 PM
generic for bilstein and koni struts....
basic bilstein
(IMG:http://www.914world.com/bbs2/uploads/thumb_blog-1140922986.jpg)
coleman adpater rings makes OD slightly larger to avoid dropping a perch (happen to grantsfo iiirc)
(IMG:http://www.914world.com/bbs2/uploads/thumb_blog-1140922998.jpg)
5" collar 2.04 ID iirc....
(IMG:http://www.914world.com/bbs2/uploads/thumb_blog-1140922938.jpg)
spring and top hat
(IMG:http://www.914world.com/bbs2/uploads/thumb_blog-1140923023.jpg)
Trekkor
post Jun 22 2006, 10:20 PM
I do things...
Andy's are ground control like mine.
I have a set of "like new" 150# Eibach rear springs I'll sell.
KT
Air_Cooled_Nut
post Jun 22 2006, 10:26 PM
914 Ronin - 914 owner who lost his 914club.com
QUOTE(Mueller @ Jun 22 2006, 09:24 PM) *
nothing special about either kit unless you like to throw money away for a fancy name......
the threaded tube and perch are just chunks of aluminum, one is no better than the other...some people think that the Eibach springs are better than the cheaper coil over springs sold by the circle-track guys....I doubt anyone here would know the differance unless you are a paid professional...if it makes you feel good to spend the extra money and throw around names like "ground-control or weltmeister or even Eibach" knock yourself out (IMG:style_emoticons/default/smile.gif)
So you recommend keeping everything stock, right? If not, what did YOU do?
Trekkor
post Jun 22 2006, 10:32 PM
I do things...
I think the adj perches were around $25 ea. And the the Eibach's were $125 for the pair.
Is that "expensive"?
KT
monkei
post Jun 22 2006, 10:36 PM
slave to rust....
i think he's simply recommend i dont base my decision on name or price... id have to agree, i was planning on basing my decision on fellow 914 enthusiasts experience. so far ive discovered there may be a cheaper bolt on alternative to the kits i suggested (ala aaron cox), not sure of p/ns and manufacturers yet.
trekkor, how much for springs? the perches for coilovers are all thats needed beyond struts/springs? 25$ for ground control each?
Trekkor
post Jun 22 2006, 10:49 PM
I do things...
How about $90 inc shipping?
Check prices with Rich on the perches.
KT
nebreitling
post Jun 23 2006, 12:38 PM
Member Emeritus
I've got eibach 200#'s and QA1 225#'s, and i must say that the QA1's, which were significantly cheaper, were also significantly heavier.
Aaron Cox
post Jun 23 2006, 12:43 PM
i have AFCO - afcoil springs... 225 rate....
30 a pair NEW - got a smoking deal...
the dirt track guys have lots of cheap take off springs
turboman808
post Jun 23 2006, 12:44 PM
I think what I like most about ground control is that ordering various rate springs is pretty cheap. $60 a spring last time I ordered.
Dr Evil
post Jun 23 2006, 12:46 PM
Send me your transmission!
Awsome, I was just looking for ALL of this info as my car is stink bugging pretty bad.
Thanks guys!
Aaron Cox
post Jun 23 2006, 12:49 PM
QUOTE(turboman808 @ Jun 23 2006, 11:44 AM) *
uh... hypercoils, eibachs and others are cheaper or the same price (IMG:style_emoticons/default/smile.gif)
mikelsr
post Jun 23 2006, 02:09 PM
QUOTE(Aaron Cox @ Jun 22 2006, 10:59 PM) *
colemanracing.com
To show my ignorance, when you put adjustable spring perches on do you have to weld them on or do they sit over the top of the shock held on by the spring?
Now they are $37.65 minimum...
Mike
TravisNeff
post Jun 23 2006, 02:20 PM
Hypercoils run about 60 per pair. they go in 5lb increments. See paragon-products.com.
The coleman option looks like a great bang for the buck
Aaron Cox
post Jun 23 2006, 02:56 PM
QUOTE(mikelsr @ Jun 23 2006, 01:09 PM) *
colemanracing.com
Mike
look at the pics i posted, and in my blog.
they sit on a circlip (on koni's and bilsteins)
37 each side + 2 "adapter rings" (search it at coleman, 5 bucks each) + springs. DONE
Aaron Cox
QUOTE(Travis Neff @ Jun 23 2006, 01:20 PM) *
no way they are 60 a pair... they are 60 each....
- Lo-Fi Version Time is now: 14th April 2026 - 07:02 AM
