| Dave_Darling |
Jun 23 2006, 04:23 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,338 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
I have the Weltmeisters. Got them about eight or ten years ago, when nobody else would fess up to making 'em for 914s. They work fine--nothing super special about them. The springs are short enough that they come off the perches at full droop (e.g., when the car is on jack stands) so you have to take care putting the car back on the ground. You can (and I did) zip-tie the springs to the upper perch, through the holes provided for that purpose. But it is not a complete cure.
Nowadays, I'd give the cheapie ones some very serious consideration... --DD |
| Aaron Cox |
Jun 23 2006, 04:25 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
or we could all just engineer threaded body shocks and not have to get coilover sleeves (IMG:style_emoticons/default/smile.gif)
bilstein has some great racer shocks that are completely "racer rebuild"-able and sell bazillions of valving kits.... |
| Brad Roberts |
Jun 23 2006, 04:27 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
The reason I buy Eibach springs:
I *could* buy them in lower increments for fine tuning compared to the dirt track spring rates which would jump in 50lb increments. I also needed the option of spring height. 8inch/10inch/12inch. Some of the others in the past didnt have many options. I went with Ground Control components because they support OUR industry (AutoX+Road racing) I use Coleman for other products and have since 1993. I like their brake rotors and hats (this is what they are known) I also get what I pay for. The quality of the Ground Control stuff (that everyone can make) is FAR better than the cheap appearing, cheaply made cast stuff that Coleman sells. I have also noticed the Coleman threaded pieces have a lot of "slack" in them compared to the more precise GC units. My .02 B |
| Aaron Cox |
Jun 23 2006, 04:30 PM
do ground control setups use a double nut approach to locking the perch? or do they do a set screw like coleman?
i somewhat agree with brad, the sleeves coleman makes are nice. the perch ring/nut does have a little slack. each perch is sold in 2.04 and 2.08 ID setups... they also sell a little adapter ring to take up any slack between the body and the sleeve.... AA |
| TravisNeff |
Jun 23 2006, 04:50 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region
Hypercoils run about 60 per pair. they go in 5lb increments. See paragon-products.com. The coleman option looks like a great bang for the buck no way they are 60 a pair... they are 60 each.... Well, I must have received a 1/2 price discount. (IMG:style_emoticons/default/wink.gif) |
| Aaron Cox |
Jun 23 2006, 04:52 PM
Hypercoils run about 60 per pair. they go in 5lb increments. See paragon-products.com. The coleman option looks like a great bang for the buck no way they are 60 a pair... they are 60 each.... Well, I must have received a 1/2 price discount. (IMG:style_emoticons/default/wink.gif) that would be killer if you did.... |
| TravisNeff |
Jun 23 2006, 04:55 PM
Hypercoils run about 60 per pair. they go in 5lb increments. See paragon-products.com. The coleman option looks like a great bang for the buck no way they are 60 a pair... they are 60 each.... Well, I must have received a 1/2 price discount. (IMG:style_emoticons/default/wink.gif) that would be killer if you did.... I am talking about the springs, not the perch kit - and yes 60-65$ bux from paragon |
| mikelsr |
Jun 23 2006, 04:56 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 657 Joined: 2-January 05 From: Mahomet, IL Member No.: 3,390 Region Association: Southwest Region |
| monkei |
Jun 24 2006, 02:05 AM
slave to rust.... ![]() ![]() Group: Members Posts: 137 Joined: 10-August 04 From: Pleasanton, CA Member No.: 2,504 |
so the coleman parts are cast and the ground control kits have machined t6 or something similar?
| Andyrew |
Jun 24 2006, 02:36 AM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,380 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
The springs are typically 50-60 a piece.
Lo-Fi Version | Time is now: 16th April 2026 - 08:35 AM |
