| Brando |
Jun 24 2006, 03:39 PM
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
I have a question about electric flasher units. I would like to replace my incadescent bulbs/lamps with LEDs, to trim the wattage/amperage usage. I've noticed when my electrical system is under load I get a bit of extra load on my 1.8 as the alternator is working itself to death. Also when using LED lights in place of the incadescent ones, they don't pull enough amperage to trigger my OEM flasher (heat-driven).
Anyhow, does anyone make electrical flasher units? Where can I get one that I might even be able to wire in myself? I have knowledge on electrical systems (diagrams, simple circuits, etc) but nothing as complex as making my own up. Has anyone replaced their OEM flasher unit with an electrical one? TIA. |
| alpha434 |
Jun 24 2006, 03:43 PM
My member number is no coincidence. ![]() ![]() ![]() ![]() Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains |
Go to radio shack dot com and order one of their industrial catalogs.
And it'll be really cheap too. |
| Brando |
Jun 24 2006, 04:05 PM
I found one. Not bad! Adjustable Flashing Unit.
| alpha434 |
Jun 24 2006, 04:54 PM
Excellent find, brandon. So are you going to wire all four lights through one relay or get another relay and wire 2 seperates.
To wire through one, you would put the relay before the switch in the circuit. To wire two, run two in parallel each one hooked up to each side's lights (after the switch.) How much current do those units flow? |
| Brando |
Jun 24 2006, 05:33 PM
I think I'll run one for both sides and the hazards. This will work great with my wide-angle LED bulbs I bought oh-so-long-ago at Superbright LEDs. I'm not sure how much current they flow. Like I said, I'm no EE, I just know it has to be 12V and use <= 15 Amperes. Here's the specs from the eBay auction:
Operating Systems: 6 Volt and 12 Volt Operating Voltage: 5 Volts to 17 Volts DC Max Current: 15 Amperes Max Watts: 180 Watts Dimensions: 1.8" X 0.8" X 0.3" (aprox.) Selectable Flash Rates:- 90, 60, 50 or 40 per Min. (aprox.) |
| lapuwali |
Jun 24 2006, 05:52 PM
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
The current the LEDs draw will be well under 1A. There are lots of electronic flashers available now at most FLAPs. Most of them aren't adjustable, but they're more readily available. Some of them have nice loud noisemakers to remind you they're on, so you don't look like an old geezer driving for miles with the thing on.
| Engman |
Jun 24 2006, 06:15 PM
Zoisite ![]() ![]() ![]() Group: Benefactors Posts: 1,349 Joined: 25-March 03 From: New Albany, IN Member No.: 475 |
Having just designed an led system for a euro product we are doing - I would be concerned.
I use on the euro mower I just did - 2 led turn signals on each side of the vehicle - each light draws .25A so there is a .5A draw on the flasher unit. I went with what the lighting company recommended - (Grote Industries). When I go the led flasher relay I wanted to see it work. It did not - after talking with the tech rep there I learned that the flasher unit I got required 1A of draw to work. I had to go to another led flasher relay that they had just come out with - requires .06A draw. It worked. Watch your specs - You should be able to wire it in - just get the correct wires to the correct plug on the flasher relay. M |
| jk76.914 |
Jun 24 2006, 06:45 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
I have a question about electric flasher units. I would like to replace my incadescent bulbs/lamps with LEDs, to trim the wattage/amperage usage. I've noticed when my electrical system is under load I get a bit of extra load on my 1.8 as the alternator is working itself to death. Also when using LED lights in place of the incadescent ones, they don't pull enough amperage to trigger my OEM flasher (heat-driven). Anyhow, does anyone make electrical flasher units? Where can I get one that I might even be able to wire in myself? I have knowledge on electrical systems (diagrams, simple circuits, etc) but nothing as complex as making my own up. Has anyone replaced their OEM flasher unit with an electrical one? TIA. I'm curious how you know your electrical system is under load??? Jim |
Lo-Fi Version | Time is now: 1st May 2026 - 06:12 PM |
