| shaggy |
Jun 24 2006, 05:30 PM
mechanic/welder/fabricator ![]() ![]() ![]() Group: Members Posts: 702 Joined: 26-September 05 From: Gilbert, AZ Member No.: 4,869 Region Association: None |
im changing out my 72 1.7 for a 73 2.0
i have a rescently rebuilt tailshift tranny since ill have it seperated and im putting a new clutch in what else should i change? i cant change to side shift at this point and i dont have the money for a renn shifter should i change the bushings out? if so what ones? -shaggy |
| gregrobbins |
Jun 24 2006, 05:44 PM
Member: Team NARP ![]() ![]() ![]() Group: Members Posts: 1,515 Joined: 23-March 04 From: Arizona Member No.: 1,844 Region Association: Southwest Region |
Before reassembly, get your rotating parts balanced. Cams and lifters are cheap and vital, so you may want to look at getting those new. New bushings for the shift linkage are a good idea. Are you doing fuel injection? You may want to get the injectors checked or replace them. I just had my 2.0L rebuilt, so feel free to call with any questions.
| shaggy |
Jun 24 2006, 05:50 PM
im going to used the raby cam that will work with stock d-jet
the 9550 i believe... what would need to be balanced besides the flywheel and the crank? how much does that cost and does anyone know of a good shop in arizona? thanks -shaggy |
| gregrobbins |
Jun 24 2006, 06:35 PM
What to balance:
Crank, pistons, connecting rods, fly wheel, pressure plate, and cooling fan. Every thing that rotates. Mine was done by King Balancing in Glendale. |
| Al Meredith |
Jun 24 2006, 06:47 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 984 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
If you are going to keep the tail shifter then I would replace ALL the shift bushings including the two balls next to the firewall. This is where the shift linkage changes direction and if the BOOT is broken or gone then dirt is in there.
| Mark Henry |
Jun 24 2006, 07:51 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
You will also need to use the '72 engine bar.
| Red-Beard |
Jun 24 2006, 08:21 PM
"Ya canna change the laws of Physics" ![]() ![]() ![]() Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
You also should take apart the gear selector in the cabin and replace the 2 bushings and spring in there. See the end of my tranny rebuild article for part numbers. Check for wear in the contact area between the shift rod and the tail shift tail connection. Once you fix all of this, adjust the gear selector using the direction at the end of my tranny rebuild article.
Lo-Fi Version | Time is now: 15th July 2026 - 04:51 AM |
