> my teener runs better than ever, after some service at Rudi's
Gustl
post Jun 25 2006, 01:55 AM
914 enthusiast & historian
Region Association: Austria
As some of you might know, my mechanic abilities are not the best - I'm more the "theoretic guy". Therefore I have an affordable professional mechanic, it's the younger brother of an good old friend. He works for a Hamburger and a Coke, if you know what I mean.
So far so good, but this guy - Daniel - is younger than my teener and so he hardly knows anything about it's technique. I'm not talking about changing oil or valve adjustment, I thought more about things where it would be a benefit to have some experiences with (e.g. rear calipers or mechanic ignition).
So I decided to bring my teener to Rudi's shop this year. This is a friend from the bavarian 914 group (Germany) - for example, he services the "Singer GT", which is unbeaten in historic races in its class for the last couple of years ...
Rudi has about 20 years experience with working on teeners.
I told him my knowledge about the history and some known problems and asked him to check the whole car.
Last week he told me at the phone that there were some significant problems with the suspension setup and the ignition system, but no "expensive problem".
Friday I drove to Rudi's to get my teener back. It was a 2-hours-trip (one direction) and €260, but it was worth every cent and every minute.
The car handles better than ever, especially on twisty roads (IMG:style_emoticons/default/driving.gif)
The engine runs better than ever, no more starting problems or too low rpm in neutral ... I didn't know that a teener can run that good (IMG:style_emoticons/default/mueba.gif)
Now I hope that the weather gets better that I can enjoy more time with my teener
(IMG:style_emoticons/default/wavey.gif) Gustl
VegasRacer
post Jun 25 2006, 05:11 AM
ELVIRA
Good news. (IMG:style_emoticons/default/aktion035.gif) Enjoy.
914Sixer
post Jun 25 2006, 06:30 AM
Sweeeeet! It makes driving alot more fun!
davep
post Jun 25 2006, 07:45 AM
914 Historian
Did he detail what he had to do to the car to enhance it?
Gustl
post Jun 25 2006, 09:20 AM
QUOTE(davep @ Jun 25 2006, 03:45 PM) *
yes - not sure if I could translate every detail, but the most significant things are:
first of all - my car was lowered at the front by a PO, unfortunately the driver's side was a little lower than the passenger side (IMG:style_emoticons/default/dry.gif) as a result (??) the adjustments (camber, castor & toe-in) were incorrect
one of the tie rods was so rusty that he had to replace it
some of the parts of the ignition distributor had to be replaced (Distributor cup, contact braker point, flyweight & spring and trigger contacts IIRC)
installed new fan belt
re-adjusted all spark plugs
re-welded a broken bracket on my burch exhaust
AKAIR that's the major work he did (IMG:style_emoticons/default/idea.gif)
anyhow - I'm fully satisfied (IMG:style_emoticons/default/thumb3d.gif)
- Lo-Fi Version Time is now: 10th April 2026 - 01:34 PM
