Brand new CV's for the 914/4...using Type I CV's.., pictures of mods, this is how I did it..... |
Mueller |
Jun 26 2006, 10:24 AM
Saw a post by Guy aka 914GT about using Type I CV's since the 914 specific CV is NLA. So far Guy has not had problems and he is running a 300+ HP V8 (IMG:style_emoticons/default/burnout.gif)
So I bought a set of 4 (average price is $40 or so, Eric Shea has them in the resource area) They are not a 100% bolt on item, they are lacking the 10mm spring pin holes so 2 of the 8.5mm(?) thru holes need to be drilled to a depth of 10mm (.40") Normally I would use my mill, however I had a job setup on it and I didn't want to re-do my fixtures for that current job so I used my lathe. Not the prettiest tooling, but it works (IMG:style_emoticons/default/smile.gif) 1st pic is stock CV with un-mod'd CV on the right, lower CV has 2 holes opened up for the spring pins. 2nd pic is of the fixture, the 2 silver posts are for locating the CV, these are turned down to match the diameter of the thru holes on the CV, then I use a bar to clamp the CV down. 3rd picture shows CV having hole cut. 4th picture shows "step" cut into the CV for the gasket, Guy and others have just used RTV with good results, but I wanted to use the PITA gaskets (IMG:style_emoticons/default/screwy.gif) |
Mueller |
Jun 26 2006, 10:26 AM
the dash marks in black ink are so that I re-install the cage w/balls into the correct CV and at the correct orientation......
jonwatts |
Jun 26 2006, 10:28 AM
no rules, just wrong Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
Hey cool. Good to see you're keeping busy.
Do the girls sleep to the sound of the lathe now? |
Mueller |
Jun 26 2006, 10:29 AM
jonwatts |
Jun 26 2006, 10:41 AM
That's good, much better than lite sleepers.
mightyohm |
Since you have the lathe out, can you turn them for the gasket recess?
Aaron Cox |
Jun 26 2006, 10:42 AM
good idea!
mike, i guess this is more economical than 944 axles! they have same internal spline? so you just use the 914 axle? cool. |
Mueller |
Jun 26 2006, 10:50 AM
Since you have the lathe out, can you turn them for the gasket recess? Last picture shows the new relief for the gasket....the CV on the top right hand side.... arron, I'm using 4 lug parts still, I think the 944 parts have a larger OD for the CV. yes, the spline count is the same as is thickness, the only deviation is that the Type I has a slightly smaller OD on the end opposite of the spring pins where the boot goes, I see this as an non-issue since the mounting bolts will center the boot. |
fiid |
Jun 26 2006, 10:55 AM
That's really cool - nice job dude.
URY914 |
Jun 26 2006, 11:00 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,708 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
That's it??? Drill some holes and bang in the roll pin. Perfect. When do you go into production?
Mueller |
Jun 26 2006, 11:35 AM
That's it??? Drill some holes and bang in the roll pin. Perfect. When do you go into production? I looked into it, but I don't have a commercial account and after tax and or shipping, there wouldn't be any money in it at all (IMG:style_emoticons/default/sad.gif) |
JeffBowlsby |
Jun 26 2006, 01:49 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Price them so that there is money in them Mike. Save the 914 world, the alternatives are not...available!
markb |
Jun 26 2006, 03:06 PM
Price them so that there is money in them Mike. Save the 914 world, the alternatives are not...available! (IMG:style_emoticons/default/agree.gif) |
Brad Roberts |
Jun 26 2006, 03:25 PM
Did you fill the two remaining holes with silicon so the grease doesnt travel through the pins and out the CV boot cover?
Just a thought: the 914 tranny is a VW part. Did anyone check to see if you could use regular IRS bug output flanges on the a 914 tranny? You would'nt have to go through any of this (at least on one end!) B |
Jun 26 2006, 03:30 PM
Resident German Group: Admin Posts: 41,648 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
and while you got your lathe all fired up, why not turn down my second axle?
(IMG:style_emoticons/default/biggrin.gif) Andy |
Mueller |
Jun 26 2006, 04:32 PM
Did you fill the two remaining holes with silicon so the grease doesnt travel through the pins and out the CV boot cover? Why? The 914 CV has a thru hole for the spring pin, they too would have the same issue. Just a thought: the 914 tranny is a VW part. Did anyone check to see if you could use regular IRS bug output flanges on the a 914 tranny? You would'nt have to go through any of this (at least on one end!) Seems like more work and more cost to replace the output flange. B |
Mueller |
Jun 26 2006, 04:34 PM
and while you got your lathe all fired up, why not turn down my second axle? I've been meaning to ask you if the 944 CV's use the bevel washer or not, if they do, I need to re-machine your axles to compensate for it. (IMG:style_emoticons/default/biggrin.gif) Andy |
Brad Roberts |
Jun 26 2006, 04:38 PM
QUOTE Why? The 914 CV has a thru hole for the spring pin, they too would have the same issue. The CV does, but the boot and cover DO NOT have 6 holes like the VW B |
I've been meaning to ask you if the 944 CV's use the bevel washer or not, if they do, I need to re-machine your axles to compensate for it. what's a bevel washer ??? (IMG:style_emoticons/default/confused24.gif) Andy |
Brad Roberts |
Jun 26 2006, 04:41 PM
QUOTE Seems like more work and more cost to replace the output flange. Anyone checked to see if we can VW stub axles at the control arm. The whole idea would be to utilize a complete VW BUG IRS axle assembly one day so people could bolt something together. Not drill/mill/lathe something together. I have used a drill on 930 CV's for the early 911 spring pins. I know it works. The main question is: do the VW parts work? B |
Lo-Fi Version | Time is now: 19th May 2024 - 07:59 PM |
