Saw a post by Guy aka 914GT about using Type I CV's since the 914 specific CV is NLA. So far Guy has not had problems and he is running a 300+ HP V8
So I bought a set of 4 (average price is $40 or so, Eric Shea has them in the resource area)
They are not a 100% bolt on item, they are lacking the 10mm spring pin holes so 2 of the 8.5mm(?) thru holes need to be drilled to a depth of 10mm (.40")
Normally I would use my mill, however I had a job setup on it and I didn't want to re-do my fixtures for that current job so I used my lathe.
Not the prettiest tooling, but it works
1st pic is stock CV with un-mod'd CV on the right, lower CV has 2 holes opened up for the spring pins.
2nd pic is of the fixture, the 2 silver posts are for locating the CV, these are turned down to match the diameter of the thru holes on the CV, then I use a bar to clamp the CV down.
3rd picture shows CV having hole cut.
4th picture shows "step" cut into the CV for the gasket, Guy and others have just used RTV with good results, but I wanted to use the PITA gaskets
