Just put spacers on the back, might be a bit much |
turboman808 |
Jun 26 2006, 09:15 PM
Advanced Member Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States |
OK so I think I should have got the 1 inch spacers. But I got the 1.5 inch. It just barely rubs so I just yanked on the fenders til it fit.
What does make me nervous though is there is no hub centric ring on the hub. Hopefully as long as I keep an eye on these it should be alright. Also does moving the wheel out put a dangerous amount of stress on the trailing arm? OH but man it does look cool! |
Andyrew |
Jun 26 2006, 09:18 PM
Tighten them down till the nut is starting to snug, on all of them. and then tighten one half way, go across.. half way... ect ect...
The rear brake rotor doesnt have a ring IIRC... so theres not much you CAN do about that... It should pull itself in correctly. Stress on trailing arms? dont worry about it. Stress on bearings? Yes. Replace them 2x faster than normal.... and most cars are just getting their first replacement.... so... in about 15years would be acceptable I think. (if the bearings are fresh... If not.. I'd replace them for insurance... 100 bucks in insurance..) Andrew ya.... I got the same problem.. (IMG:http://www.914world.com/bbs2/uploads/blog-172-1150867593.jpg) |
Sparky |
Jun 26 2006, 09:29 PM
Mahna Mahna! Group: Members Posts: 1,134 Joined: 21-June 03 From: Spencer, MA Member No.: 847 |
Bearings shouldn't be an issue he has roller bearings that are only a couple of years olds. I helped install them...
Jun 26 2006, 09:36 PM
Resident German Group: Admin Posts: 41,649 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Bearings shouldn't be an issue he has roller bearings that are only a couple of years olds. I helped install them... i think andrew was talking about the wheel bearings ... (IMG:style_emoticons/default/wink.gif) Andy |
turboman808 |
Jun 26 2006, 09:37 PM
Bearings shouldn't be an issue he has roller bearings that are only a couple of years olds. I helped install them... yeah if you would like to come and do more work on my car be my guest (IMG:style_emoticons/default/biggrin.gif) I ordered steel lug nuts just for the spacers. Figure that will hold better then race lugs could be wrong though. Also putting this in tomorrow if I get a chance. Attached image(s) |
Sparky |
Jun 26 2006, 09:41 PM
Flushing is a much farther drive then Danielson is. But if your in the neighborhood... (IMG:style_emoticons/default/drunk.gif)
Wheel bearings (IMG:style_emoticons/default/confused24.gif) Is that what that noise could be?! (IMG:style_emoticons/default/bootyshake.gif) |
Andyrew |
Jun 26 2006, 09:46 PM
Ya.. I was talking about wheel bearings.. sorry...
Most "bearings" on 914's in the suspension are the wheel bearings... most people dont have roller... BTW.. My wheel spacers have different threading for the rears, then again... im usings 2in spacers.. Did you check the threads to make sure there the porsche style? |
turboman808 |
Jun 26 2006, 10:21 PM
Ya.. I was talking about wheel bearings.. sorry... Most "bearings" on 914's in the suspension are the wheel bearings... most people dont have roller... BTW.. My wheel spacers have different threading for the rears, then again... im usings 2in spacers.. Did you check the threads to make sure there the porsche style? Seem to be the same. Everything fit fine. I should have 17 inch twist next week. I don't imagine they would come by this friday. Yours are 18? Somehow I imagine I am gonna have to get 4 more spacers to make them fit. |
Sparky |
Jun 26 2006, 10:26 PM
So.... what ya doing with those nice powder coated Fuchs?
Andyrew |
Jun 26 2006, 10:33 PM
Ya.. I was talking about wheel bearings.. sorry... Most "bearings" on 914's in the suspension are the wheel bearings... most people dont have roller... BTW.. My wheel spacers have different threading for the rears, then again... im usings 2in spacers.. Did you check the threads to make sure there the porsche style? Seem to be the same. Everything fit fine. I should have 17 inch twist next week. I don't imagine they would come by this friday. Yours are 18? Somehow I imagine I am gonna have to get 4 more spacers to make them fit. Ya.. 17x8.5 with 255 40 17's and 18x10 with 285 35 18 (265 pictured) 1.5 spacer up front, 2.0 spacer on back. I would like to space the back out another 1/8... or 1/4... I love them when there right there against the fender... and I have the longer stubs to do it too..... (IMG:http://www.914world.com/bbs2/uploads/blog-172-1150867428.jpg) fyi.. yes the rims are diff... when I find the 17 turbo twists... then I get some fronts for it.. |
Mueller |
Jun 27 2006, 12:26 AM
OK so I think I should have got the 1 inch spacers. But I got the 1.5 inch. It just barely rubs so I just yanked on the fenders til it fit. What does make me nervous though is there is no hub centric ring on the hub. Hopefully as long as I keep an eye on these it should be alright. Also does moving the wheel out put a dangerous amount of stress on the trailing arm? OH but man it does look cool! at your next Auto-x, don't be too surprised when the front end plows straight ahead when trying to make a tight corner :drivingAX: (IMG:style_emoticons/default/hijacked.gif) Andrew, you need to lower that car...looks like the 4x4 version (IMG:style_emoticons/default/biggrin.gif) |
Joe Ricard |
Jun 27 2006, 07:16 AM
I thought that setting the rims out further will cause that end to slide .
So putting spacers on the rear will cause Oversteer However I have been wrong ALOT lately. |
Aaron Cox |
Jun 27 2006, 07:21 AM
turboman808 |
Jun 27 2006, 10:20 AM
Didn't push it real hard this morning but it felt like the rear did roll more. But hey I always got the front sway bar to play with.
Eric_Shea |
Jun 27 2006, 11:03 AM
QUOTE Andrew, you need to lower that car...looks like the 4x4 version Raise the front and bring it to Moab (IMG:style_emoticons/default/w00t.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 08:32 PM |
