What size CV's do I have? |
GWN7 |
Jun 28 2006, 09:31 PM
So it runs. Drove it tonight. (IMG:style_emoticons/default/biggrin.gif) I looked like this afterwards (IMG:style_emoticons/default/w00t.gif)
But while finishing it up I found I was short one CV plate (plate is what Porsche calls them). Guess the guys that dropped the Schnorr washers also dropped the plate. NP I thought, I'll just use one off the parts car. I slide it on and start to hand tighten the bolts and it binds. WTF!! I pull it off and one of the original ones that I had just put on and compare. The stock CV plate is on top of the one from the car in picture 1 and the two side by side in picture 2 So what size/type CV's do I have? I'm guessing the output flanges are different than stock also, for the CV to bolt up to it? The bolts are a couple mm longer than stock also. I tryed to use ones off the parts car and they wouldn't tighten down. Attached image(s) |
Joseph Mills |
Jun 28 2006, 09:48 PM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
[quote name='GWN7' date='Jun 28 2006, 10:31 PM' post='715255']
So it runs. Drove it tonight. (IMG:style_emoticons/default/biggrin.gif) I looked like this afterwards (IMG:style_emoticons/default/w00t.gif) I "feel" your joy! (IMG:style_emoticons/default/biggrin.gif) "The stock CV plate is on top of the one from the car in picture 1 and the two side by side in picture 2 So what size/type CV's do I have? " The top pic is the very same as my "plates" Maybe the other "plate" is VW? More knowledgeable than I will respond. (IMG:style_emoticons/default/biggrin.gif) "The bolts are a couple mm longer than stock also. I tryed to use ones off the parts car and they wouldn't tighten down." VW bus? Dang! I'm lost as you are. (IMG:style_emoticons/default/biggrin.gif) Glad to hear that it's a runnin'! .. .. |
Lo-Fi Version | Time is now: 19th May 2024 - 10:28 PM |
