tranny gears sets, is there a chart somewhere? |
jimkelly |
Jun 29 2006, 06:16 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
I have a total of 6 trannys disasembled in boxes and started to remove the dogteeth so I can move them along with the bands and sliders to another box so I can sort them out for god ones and bad ones but now I am left with lots of gears. Some have a letter stamped on them and others have info engraved on them. So far I remember seeing U, P, Z or N (not sure) stamped on and some have ( II ) engraved on them in front of the engraved letter. Are the stamped one for one shaft and the engraved ones for the other shaft thus matching gear? Thanks Jim
I finally swapped bad dogteeth, bad sliders and bad bands for better ones in my tail shifter and it took several hours. I have several hours to go until tranny is completely reassembled. I am begining to understand the really tremendous value of Dr. Evil's tranny rebuild service and would suggest at least some new syncro bands to anyone rebuilding a tranny as most of mine looked like crap, they are the cheapest parts in the tranny, and your more expensive parts will last longer with new bands. |
fitsbain |
Jun 29 2006, 06:50 AM
Ask me if my car has rust!!! Group: Members Posts: 619 Joined: 25-February 06 From: Pittsburgh PA Member No.: 5,634 |
Sometimes you will even get lucky and find good parts.
E. opened up 2 at my plce and found almost everything in very good shape. |
Aaron Cox |
Jun 29 2006, 07:23 AM
the markins are usually worthless...
you need to do a teethcount. its a ratio X:Y 11:34 is an 'A' first gear.... for example i have a chart in my blog somewhere |
jimkelly |
Jun 29 2006, 07:37 AM
http://www.914world.com/bbs2/index.php?auto...ach&id=3082
COOL THANKS JIM GEAR SETS GEAR RATIO GEAR RATIOS TRANNY GEARS GEAR SET |
Lo-Fi Version | Time is now: 30th May 2024 - 03:20 PM |
