I hate to ask this |
jkslvr |
Jun 29 2006, 02:19 PM
Newbie Group: Members Posts: 11 Joined: 26-June 06 From: Denver Member No.: 6,307 |
How do you get to the spark plugs on a 2.0L.
I need to replce cyl #2 |
Allan |
Jun 29 2006, 02:34 PM
Just locate #2 plug, pull the plug wire and R&R plug.
tdgray |
Jun 29 2006, 02:39 PM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
Make sure you plug socket has the little rubber gasket on the inside or you'll loose your spark plug under the tin.
jkslvr |
Jun 29 2006, 02:40 PM
ok, I found the wire, but do I pull it out? It does not want to budge. or is there something I need to remove? then pull the wire off the plug and replace?
tdgray |
Jun 29 2006, 02:41 PM
Nope nothing to remove.
Wire has a long hard plastic insulator on it. Pull hard... but not too hard. (IMG:style_emoticons/default/biggrin.gif) |
Allan |
Jun 29 2006, 02:50 PM
And try to wiggle it a little...
tdgray |
Jun 29 2006, 02:53 PM
And try to wiggle it a little... Thats what she said... (IMG:style_emoticons/default/av-943.gif) Oh come on you didn't think we were going to get thru a whole thread without a smart ass comment did you (IMG:style_emoticons/default/biggrin.gif) |
TROJANMAN |
Jun 29 2006, 02:56 PM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
this is like the Todd and Allen Show.
Allan |
Jun 29 2006, 03:01 PM
I could see her ears move when I did.... (IMG:style_emoticons/default/slap.gif)
Rand |
Pull on the plastic insulator/connector at the end, not the wire itself. If you pull hard on the wire you can pull it out of the insulator (especially with the type that has a tip that screws into the core of the wire).
Given that, don't worry about how hard to pull. Pull 'til it comes off! Now, just curious... since you don't know how to pull plug wires, how do you know you need to replace plug #2? |
jkslvr |
Jun 29 2006, 03:50 PM
haha
No, I have not worked on 914s, only audis and stuff. So I checked the distibutor and a series of other things. and came to the conclusion that the plug was bad. the plug is getting a spark but the cyl is not firing. I just did not want to pull on something I shouldnt |
Rand |
Jun 29 2006, 04:30 PM
The easy way I know to find the cylinder that's not firing is by pulling plug wires one at a time. You haven't pulled plug wires, but you have concluded that plug #2 was bad by "checking the distributor and a series of other things." Please elaborate.
Lo-Fi Version | Time is now: 19th May 2024 - 12:03 PM |
