jkslvr
Jun 29 2006, 02:19 PM
How do you get to the spark plugs on a 2.0L.
I need to replce cyl #2
Allan
Jun 29 2006, 02:34 PM
Just locate #2 plug, pull the plug wire and R&R plug.
tdgray
Jun 29 2006, 02:39 PM
Make sure you plug socket has the little rubber gasket on the inside or you'll loose your spark plug under the tin.
jkslvr
Jun 29 2006, 02:40 PM
ok, I found the wire, but do I pull it out? It does not want to budge. or is there something I need to remove? then pull the wire off the plug and replace?
tdgray
Jun 29 2006, 02:41 PM
Nope nothing to remove.
Wire has a long hard plastic insulator on it.
Pull hard... but not too hard.
Allan
Jun 29 2006, 02:50 PM
And try to wiggle it a little...
tdgray
Jun 29 2006, 02:53 PM
QUOTE(Headrage @ Jun 29 2006, 04:50 PM)
Thats what she said...
Oh come on you didn't think we were going to get thru a whole thread without a smart ass comment did you
TROJANMAN
Jun 29 2006, 02:56 PM
this is like the Todd and Allen Show.
Allan
Jun 29 2006, 03:01 PM
I could see her ears move when I did....
Rand
Pull on the plastic insulator/connector at the end, not the wire itself. If you pull hard on the wire you can pull it out of the insulator (especially with the type that has a tip that screws into the core of the wire).
Given that, don't worry about how hard to pull. Pull 'til it comes off!
Now, just curious... since you don't know how to pull plug wires, how do you know you need to replace plug #2?
jkslvr
Jun 29 2006, 03:50 PM
haha
No, I have not worked on 914s, only audis and stuff. So I checked the distibutor and a series of other things. and came to the conclusion that the plug was bad. the plug is getting a spark but the cyl is not firing.
I just did not want to pull on something I shouldnt
Rand
Jun 29 2006, 04:30 PM
The easy way I know to find the cylinder that's not firing is by pulling plug wires one at a time. You haven't pulled plug wires, but you have concluded that plug #2 was bad by "checking the distributor and a series of other things." Please elaborate.
