Kumho Victoracers, how much -camber? |
sww914 |
Jun 29 2006, 08:44 PM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
I've just installed camber plates in the front, now that I can adjust to whatever I want, how much negative camber should I run? I'm going to modify the rear to get more -camber also, I should be able to adjust to any settings that I desire.
DanT |
Jun 29 2006, 08:48 PM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
I've just installed camber plates in the front, now that I can adjust to whatever I want, how much negative camber should I run? I'm going to modify the rear to get more -camber also, I should be able to adjust to any settings that I desire. With stock camber boxes etc....I am running -2.25 in front and -2.75+ in the rear. 205x50x15 Victors on 5.5" Fuchs with 3/4" spacers in front and 1/2" spacers in the rear. The tires are wearing very evenly at these settings. My car is VERY low. (IMG:style_emoticons/default/biggrin.gif) |
nebreitling |
Jun 30 2006, 02:09 PM
Member Emeritus Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
I've just installed camber plates in the front, now that I can adjust to whatever I want, how much negative camber should I run? I'm going to modify the rear to get more -camber also, I should be able to adjust to any settings that I desire. what kind of camber plates? i doubt that you'll be able to get more than -2.5 without getting out the die grinder. maybe with decambered balljoints thrown in the mix... http://www.elephantracing.com/suspension/b...11balljoint.htm anyway, for an aggressive driver in a track-914, i think it's hard to get too much -camber. i'm running about -3 on my front end, and i still can't get the inside of the tire to wear. back end is fine at around -2.5. |
grantsfo |
Jun 30 2006, 02:23 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
I've just installed camber plates in the front, now that I can adjust to whatever I want, how much negative camber should I run? I'm going to modify the rear to get more -camber also, I should be able to adjust to any settings that I desire. what kind of camber plates? i doubt that you'll be able to get more than -2.5 without getting out the die grinder. maybe with decambered balljoints thrown in the mix... http://www.elephantracing.com/suspension/b...11balljoint.htm anyway, for an aggressive driver in a track-914, i think it's hard to get too much -camber. i'm running about -3 on my front end, and i still can't get the inside of the tire to wear. back end is fine at around -2.5. I with my car fairly slammed I can only grab about -2 in the front. I know Nathan has his ground out to grab more. I couldnt stomach grinding my car. I'm sure that eventually I'll do something. |
nebreitling |
Jun 30 2006, 02:29 PM
keep in mind, the lower you go on a stock front end, the more static -camber you'll be able to achieve -- but the less dynamic -camber you'll gain in bump. it you go TOO low, it's possible to actually gain +camber in bump.
grinding the car isn't hard or even terribly intrusive. a little grind of the back can free up some castor, too, if you're so inclined. check the rule book before cutting, though. |
grantsfo |
Jun 30 2006, 04:56 PM
Didnt notice those decambered ball joints - thats cool!
nebreitling |
Jun 30 2006, 04:58 PM
yeah, $350 cool!
sww914 |
Jun 30 2006, 07:01 PM
My car is hardly a virgin, more like an old retired whore working at 7-11, so I reamed her good, and now it looks like about -3 degrees in front. I'll measure it soon, when my camber guage shows up next week.
nebreitling |
Jun 30 2006, 08:25 PM
My car is hardly a virgin, more like an old retired whore working at 7-11, so I reamed her good, and now it looks like about -3 degrees in front. I'll measure it soon, when my camber guage shows up next week. lmfao... we should all drive old retired whores... feel less guilt abusing them. |
Lo-Fi Version | Time is now: 12th May 2024 - 10:37 PM |
