Oil Cooler install...................., finally got it installed and connected |
East coaster |
Jun 30 2006, 09:53 PM
Senior Member Group: Members Posts: 1,668 Joined: 28-March 03 From: Brigantine, NJ Member No.: 487 Region Association: None |
Installed my oil cooler today. Some folks probably saw the thread where this setup was created so I won't go into any detail here. The first step was to apply some foam tape to all the sealing surfaces before installing the intake plenum. This creates a seal between intake and the body.
pics: |
East coaster |
Jun 30 2006, 09:56 PM
I used very thin, easily compressable foam to seal between the coolr and the intake plenum.
East coaster |
Jun 30 2006, 10:00 PM
Here's the outlet (or exhaust) plenum. I bonded three small fans into the plenum for a "traffic jam" scenario. I don't feel I'll need these otherwise. They'll be hooked to a switch and only used if/when needed. They actually throw quite a bit of air.
East coaster |
Jun 30 2006, 10:05 PM
Next came installing the plenums, cooler and oil lines. I used 45 degree bulkhead fittings under the tank. That gave the hose a nice path to the cooler.
grasshopper |
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
Randal |
Jun 30 2006, 10:06 PM
Here's the outlet (or exhaust) plenum. I bonded three small fans into the plenum for a "traffic jam" scenario. I don't feel I'll need these otherwise. They'll be hooked to a switch and only used if/when needed. They actually throw quite a bit of air. Beautiful! (IMG:style_emoticons/default/smile.gif) |
Eric_Shea |
Jun 30 2006, 10:07 PM
grantsfo |
Jun 30 2006, 10:08 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
Do you have to call the Geek Squad if one of those fans goes bad? (IMG:style_emoticons/default/biggrin.gif)
East coaster |
Jun 30 2006, 10:09 PM
The intake flanges pass through the openings in the body and air dam. It gives it kind of a buck tooth smile (IMG:style_emoticons/default/biggrin.gif)
East coaster |
Jun 30 2006, 10:14 PM
I also intalled the gas tank and the car's ready to sit on it's wheels for the first time. I plan to get it off the stand it's on and hopfully install the engine this weekend!
Here's the heart of the beast ready for installation (after I bolt the sheet metal on) |
East coaster |
Jun 30 2006, 10:22 PM
Do you have to call the Geek Squad if one of those fans goes bad? (IMG:style_emoticons/default/biggrin.gif) That's a good one!! (IMG:style_emoticons/default/beerchug.gif) |
East coaster |
Jun 30 2006, 10:24 PM
Here's the link for the making of the plenums and oil cooler mounting:
http://www.914world.com/bbs2/index.php?show...c=46489&hl= |
AZ914 |
Jul 1 2006, 08:38 AM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
dang nice!!! (IMG:style_emoticons/default/smilie_pokal.gif)
spunone |
Jul 1 2006, 09:18 AM
Senior Member Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California |
Those fans work great .I use 2 on my amp in my boat moves enough air to keep it cool from shutting down when it's 117 degrees outside.Great setup (IMG:style_emoticons/default/clap56.gif)
RON S. |
Jul 1 2006, 12:18 PM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
That is beautiful, (IMG:style_emoticons/default/thumb3d.gif) (IMG:style_emoticons/default/thumb3d.gif) (IMG:style_emoticons/default/thumb3d.gif)
I must say,we have some serious craftsman associated with this site. Way yo go! Ron |
machina |
Jul 1 2006, 02:25 PM
that is the nicest cooler install I have seen but I don't think those tiny fans are going to do anything but block the airflow.
Lo-Fi Version | Time is now: 13th May 2024 - 05:42 AM |
