Anyone using RX7 oil cooler, need help, which one is in and direction of thermostate |
dougcoup |
Jul 1 2006, 03:44 PM
Member Group: Members Posts: 131 Joined: 5-March 05 From: mundelien, il Member No.: 3,715 |
I have a RX7 Turbo oil cooler that I was using and blowing the oil filter seal with and I removed the thermostat to bypass it.
I met a Rich (nice GT5) at Gingerman the other day and he was running one too with the thermostate. Question: Anyone else running this set up? Which port is the in and the out (one on side or one on end? Could oil coolers plumbed wrong on the in and out actually create enough back preasure to blow a seal? Doug |
Joe Ricard |
Jul 1 2006, 07:31 PM
waitng for the answer too. I have a RX-7 cooler ready to go in.
jhadler |
Jul 6 2006, 03:00 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
The general use for the RX-7 cooler is to remove the thermostat and weld in AN fittings. At that point, there is no "in" and "out" port, it's just like all other oil coolers.... Even with the T-stat, it's just a bypass when the oil is cold.
-Josh2 |
Heeltoe914 |
Sep 12 2006, 08:15 PM
Senior Member Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 |
The general use for the RX-7 cooler is to remove the thermostat and weld in AN fittings. At that point, there is no "in" and "out" port, it's just like all other oil coolers.... Even with the T-stat, it's just a bypass when the oil is cold. -Josh2 (IMG:style_emoticons/default/agree.gif) |
jhadler |
Sep 12 2006, 10:39 PM
Hey Heeltoe,
I have one of those light ube skylights in my house. Pretty cool. I don't know if it's one of yours, or some other company, but it really lights up the room. Pretty neat. -Josh2 |
davep |
Sep 30 2006, 08:29 PM
914 Historian Group: Benefactors Posts: 5,137 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I don't know if you have already factored this in, but one friend told me that he had to warm his car up slowly and carefully to ensure ALL the oil was up to temperature before taking the car onto the track. All his hasty friends kept blowing up their oil coolers by trying to pump cold vicuous oil through their coolers. He waited until the thermostat had openned and the oil in the cooler loop was up to temperature.
Lo-Fi Version | Time is now: 29th April 2024 - 08:37 AM |
